Old 05-16-2021, 09:20 PM   #1
Caleb.m1
Caleb.m1 is a jewel in the roughCaleb.m1 is a jewel in the roughCaleb.m1 is a jewel in the rough
Default 02 Saturn s series gauge cluster
So the cluster says no and won't turn on. However. If I unplug and plug back in the cluster. Wham bam works great. Turn it off, remove key, then turn back on. Works a dream. Let it sit five minutes. Toasted till I either unplug and plug back in or disconnect and reconnect the battery. Wiggling wires does nothing. I tested both grounds on the connector. They ground. Took 12V to each pin that wasn't a ground and nothing would make it jump for joy.
Caleb.m1 is offline   Reply With Quote
Old 05-17-2021, 09:26 AM   #2
Default Re: 02 Saturn s series gauge cluster
Sounds like the cluster has failed in some random unique way that makes 3rd gens so amazing. I've not seen it cause a fail to start before, even when putting clusters in from other cars the worst that happens is either a CEL or various other idiot lights stay on.
Old 05-17-2021, 11:04 AM   #3
If I'm not mistaken, the S-series models from 2000+ uses a body control module (BCM) to drive the instrument panel cluster (IPC), indicators, gauges and lights. The exceptions are abs and airbag lights; they're driven by their own modules. The bcm may be problem.
Old 05-27-2021, 11:20 AM   #4
zero_cool09
zero_cool09 will become famous soon enoughzero_cool09 will become famous soon enough
1999 SL1
I don't know what clusters are going for at junkyards these days. But maybe consider buying another one to isolate the issue. You can quickly tell if its the cluster's problem if another one works just fine. Then at that point you could decide if you want to keep your mileage and repair said cluster.
zero_cool09 is offline   Reply With Quote
Old 05-27-2021, 11:35 AM   #5
El_bell
El_bell is on a distinguished road
El_bell's Avatar
3rd gens store mileage in the BCM, so they wouldn't even have to worry about it with a junkyard cluster. One of the few nice things that came out of the BCM imo
El_bell is offline   Reply With Quote
New gauge cluster... soulsurvives L-Series General 12 09-21-2016 09:19 AM
1998 Saturn SC2- Doing Away With Gauge Cluster zoman1719 S-Series Mods 3 01-13-2014 10:12 AM
Changing Color of Late-Model S-Series Stock Gauge Cluster Jim Dunlop How-To Library 39 07-22-2013 12:30 AM
Mystery Saturn White Faced Gauge Cluster in JY SaturnNJeep S-Series General 26 04-12-2010 01:40 PM
removed odometer from gauge cluster, now gas gauge & oil pressure gauge don't work DJboozeAlot S-Series Tech 18 04-06-2005 03:59 AM
