Old 05-03-2006, 03:55 PM   #1
SaturnWagon
SaturnWagon is on a distinguished road
Default Engine 1995-2001 SW1 Swap
I have a 1995 SOHC Saturn Wagon which has a bad head. I've found and bought a 2001 Saturn SOHC engine. The engine will arrive this week. I was wondering what change I will need to make to make this engine work. Do I just change the sensors and injectors? I believe the engine comes with the 2001 Intake. Do I NEED to tap the head for the extra temp sensor or can I just leave it out ?? I know the engine will fit phsyically but is there any other changes I will need to make ??? ANY help would be greatly appreciated. Thanks
SaturnWagon is offline   Reply With Quote
Old 05-03-2006, 04:10 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Engine 1995-2001 SW1 Swap
Just install the second temp sensor and that should be about it.
You can add one like this:
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 05-03-2006, 05:42 PM   #3
SaturnWagon
How do I make the same mod you did for the temp sensor? What did you use and how did you do it ?
Old 05-03-2006, 06:40 PM   #4
geartooth94
geartooth94's Avatar
tap that area of the head with a 1/4" NPT tap. or if you're unsure take it to a machine shop to do. it should take them all of 5 minutes to do.
here's another example. worked for me....
geartooth94 is offline   Reply With Quote
Old 05-05-2006, 03:14 PM   #5
SaturnWagon
OK .. SO now I have the engine.. I didn't realize it was an automatic.. Does anyone know how to convert automatic to manual ?? Do I just change the fly wheel?? Is there an extra bushing or anything eles?
Old 05-05-2006, 04:10 PM   #6
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Just swap over the flywheel. Be sure to use the flywheel bolts and not the flexplate bolts.
Mike
-1991 Turbo SL2.
2001 L Series V6 Engine Swap genie45 L-Series Tech 0 05-21-2008 11:53 AM
1994-1995 engine swap question hrtatack1 S-Series Tech 3 04-07-2008 01:04 PM
1995 DOHC swap to newer engine tjwms S-Series Tech 3 11-05-2005 09:22 PM
1995 sc1 engine swap? chaz70 S-Series General 1 10-11-2005 10:21 AM
2001 Sl engine swap help! srdude05 S-Series Mods 8 09-12-2005 02:58 AM
