Old 04-13-2021, 07:16 PM   #1
454cid
Default Auto slam in DRIVE and reverse
I've searched and am not sure I'm finding what I need. I looked at an 2002 SC2 today, that's in better shape then my SL2 in every way except the transmission. (even the sunroof and AC works!)
I did not drive it, since it's at an auction house. I did move it forward and back a couple of times, and it slams into gear.... maybe a bit more in reverse, but still in both directions.
Is this the roll pin? solenoids? valve body? Actually the slam is what breaks the pin, right?
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 04-13-2021, 08:56 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Auto slam in DRIVE and reverse
I don't think the slam would do anything to the roll pin. I'd check the ISN.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 04-13-2021, 10:40 PM   #3
billr
My understanding is that the slam is usually from a VB problem, but that could be just a bad LP solenoid. Also, I think the slam causes the ISN to loosen.
Agreed, the diff pin problem is unrelated to the slam. The diff pin has either insufficient lube for the locking provided, or insufficient locking for the lube/bearings specified. Take your pick.
Old 04-18-2021, 12:36 PM   #4
cujoe_da_man
cujoe_da_man is on a distinguished road
cujoe_da_man's Avatar
I know this isn't exactly the same thing, but the early 2000's Grand Am's had a similar issue with their transmissions, if you shifted straight into drive, the whole car would jump. It was a valve or a piston sticking (inside the tranny), but if you put it in reverse first, then down into drive, it wouldn't slam so hard.
cujoe_da_man is offline   Reply With Quote
Old 04-21-2021, 12:12 AM   #5
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
I feel like a newB... what does "ISN" stand for?
My 98 shifts harsh into drive and reverse from park. Doesn't really bother me too much, but if something minor is causing it that's easily fixable I'll try to put a stop to it.
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
98_Gold_Uranus is offline   Reply With Quote
Old 04-21-2021, 12:33 AM   #6
Waiex191
Waiex191's Avatar
Intermediate shaft nut, I believe.
Bryan Cotton
Old 04-21-2021, 01:53 AM   #7
BookerJack
BookerJack is on a distinguished road
Default Gutter Cleaning Service in Long Beach
Whether you have a commercial property or residential property, a proper drainage system is essential to maintain. We can work to change the traditional gutter system by enhancing the outlook of your home. We provide exceptional gutter cleaning service in long beach, so you have a feeling of new space around your ambiance.
BookerJack is offline   Reply With Quote
Old 04-21-2021, 08:10 AM   #8
98_Gold_Uranus
In reference to something inside the trans itself?
Old 04-21-2021, 12:05 PM   #9
billr
Actually, it is the "Input Shaft Nut". Yes, there is also a similar Output Shaft with a similar nut, but the OSN doesn't seem to ever come loose. The ISN is "inside" the trans, but not very deep. There is a cover on the driver-side end of the trans that can be removed to get to the ISN
Old 04-21-2021, 04:53 PM   #10
trottida
trottida's Avatar
My understanding of the transmission slam or sometimes called "Reverse Slam" it that it is caused by not maintaining the transmission fluid change intervals. The valve body requires relatively clean fluid.
The valve body passages start to clog up and you start experiencing reverse slam. If you leave it too long then your input shaft nut begins to back off and eventually you start losing gears.
If you catch it early on you can perform the Wolfman Reverse Slam Cure; a procedure to clear the valve body passage ways. It's a low cost easy DIY repair. Google it.
If you leave it too long then you are looking at a valve body repair/replacement and/or input shaft nut re-torque procedure. Both of which are more complex but can still be done DIY if you are game.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 04-22-2021, 02:51 AM   #11
454cid
I passed on the car.... replacing the solenoid didn't look hard, but I don't want to replace things that I don't know are wrong, and I wasn't seeing a lot of definitive advice/diagnosis in my search.
1999 Chevy K3500
I knew about auto reverse slam.... Mister_Cee S-Series General 3 11-11-2018 10:14 AM
Tran Slam From Reverse to Park and Reverse to Drive fmctaurus S-Series Tech 4 03-09-2012 11:00 AM
Auto to manual swap (reverse slam fix) Cessna S-Series Tech 12 08-15-2010 02:43 PM
Reverse Slam/Hard Drive Shifts ddechene S-Series Tech 8 01-18-2009 08:50 PM
Reverse Slam/other problems 92 SL2 Auto paxman356 S-Series Tech 5 10-27-2005 10:22 AM
