Old 04-12-2021, 04:59 PM   #1
2001-SC2
2001-SC2 is on a distinguished road
Default Auto trans leak
No symptoms yet but just starting it and moving it will leave a drop or 2.
Looks like the bottom is leaking, is there any way to seal this without removing the transmission?
2001-SC2 is offline   Reply With Quote
Old 04-12-2021, 07:54 PM   #2
Tommie
Tommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of lightTommie is a glorious beacon of light
1996 SL1
2002 SL1
Default Re: Auto trans leak
Make sure it isn't coming from somewhere else first. The top transmission cover and the transmission filter could be the source. The torque converter seal as well. Ask me how I know
Tommie is offline   Reply With Quote
Old 04-12-2021, 10:23 PM   #3
toggenburg
toggenburg's Avatar
^^ or even the drain plug/seal.
Old 04-13-2021, 09:59 PM   #4
2001-SC2
Thanks. The valve body was just replaced by a shop, and it seems like thereís a dip in the rpm for a split second on the 1-2 shift and a slight increase in rpm and a bit of a hard shift on the 2-3 shift but isnít every time.
Are there band adjustments on this? And could replacing the valve body be causing that? Thanks.
Old 04-13-2021, 10:45 PM   #5
billr
No bands, or other adjustments. However, the PCM may need to do a "learn" of the parameters for the new VB. That should occur automatically and very quickly. A full relearn may take a while, but after just a few miles/shifts the shifting should be smooth enough that you will think it is already acceptable. If you have live-data, that will show status of the trans relearn.
Auto trans leak thutton S-Series Tech 2 12-17-2007 04:20 PM
Need help with a auto trans leak... 94 SL2 Fricken eh! S-Series General 5 06-03-2006 11:11 AM
Leak from auto trans, Upper Pan area???? Fricken eh! S-Series General 5 10-20-2005 04:36 PM
Condensor Leak or Auto Trans Fluid? mfabel S-Series Tech 9 07-13-2005 12:38 AM
Auto Trans Leak ricksLS1 L-Series General 5 03-09-2004 01:32 PM
