Old 04-09-2021, 06:20 AM   #1
rgk
rgk is on a distinguished road
Default Girdle worth it?
Howdy folks,
Doing a rebuild on a '96 SW2. I've got everything put back together, and am wondering whether it would be worth it to replace the oil baffle tie plate with the larger newer girdle.
Everything on the engine is stock 1996 parts. Would the girdle make much difference without the newer crankshaft?
Also, would my existing crank cap bolts work with the girdle, or would I need new/different bolts?
Thanks.
rgk is offline   Reply With Quote
Old 04-09-2021, 08:34 AM   #2
Waiex191
Waiex191's Avatar
Default Re: Girdle worth it?
I have one car with and one without. I can't tell the difference. I wouldn't bother.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 04-09-2021, 12:38 PM   #3
rgk
That's the way I'm leaning too. How about the crank cap bolts? Are they the same?
Old 04-09-2021, 03:11 PM   #4
Waiex191
Waiex191's Avatar
I've only rebuilt the '99. I've not opened up the '98. I assume it is the same as the girdle, or windage tray bolts on separate from the main bearings. Those 6 bosses around the inside perimeter of the bottom of the case is where it bolts on.
Bryan Cotton
Well..Baby popped her girdle but i found a low mile motor..now what? kaptnjack S-Series Tech 10 05-30-2016 10:11 AM
Source for block girdle? scramblejim S-Series General 4 12-15-2011 01:29 AM
Is it worth it? JS95SC1 S-Series General 9 11-08-2009 07:24 PM
bottom end girdle sl2clone S-Series Tech 6 02-19-2007 10:42 PM
What's it Worth? floyd S-Series General 6 04-07-2006 09:22 PM
