Old 04-08-2021, 08:34 PM   #21
Melissa_M
Melissa_M is a jewel in the roughMelissa_M is a jewel in the roughMelissa_M is a jewel in the rough
Default Re: replacing serp belt
yeah, once I get this issue sorted out, I need to diagnose my non functional A/C. Crank windows and no a/c is not ideal.
1999 SL2 MANUAL ~78K
Melissa_M is offline   Reply With Quote
Old 04-09-2021, 11:41 PM   #22
At different times, the AC on my 98 and 02 stopped cooling. Both times, it was because one of the Schrader valves (basically, bicycle tire style stems you push in to release air/refrigerant) had loosened and slowly leaked.
Replacement stems are under $5, though on my 02 I just tightened it and refilled. I think I did end up replacing the valve later because I had the tool already. Of course, it was shortly after I refilled that it stopped working again because of the thermal fuse
on the 98, i noticed AC slowly getting weaker over the summer. On the 02, it worked one summer, must have leaked out over fall/winter, didnt work next summer.
serp belt fell apart mattachuz L-Series Tech 2 05-03-2011 10:21 AM
belt tensioner/removal of serp belt sc95auto S-Series Tech 2 07-02-2008 03:45 PM
Anyone need a Serp Belt for a DOHC chadfend S-Series Tech 4 11-18-2007 09:00 AM
New serp belt?? xround3x S-Series Tech 3 01-16-2007 12:54 AM
Serp Belt Just Came Off karma3 S-Series General 25 09-05-2006 11:15 AM
