Old 07-08-2019, 05:58 PM   #1
prioris
prioris is a jewel in the roughprioris is a jewel in the roughprioris is a jewel in the rough
Default does heating a tie rod for alignment make sense
I had alignment done and they also heated the tie rod.
Service guy said it had to be done for alignment
He also said is done to reduce stress on joints
Never had that done on my 1999 Saturn SL1 before.
Does this makes sense
prioris is offline   Reply With Quote
Old 07-08-2019, 06:04 PM   #2
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
Default Re: does heating a tie rod for alignment make sense
That's a new one. They're cheap. If they're not tight toss them in the trash and replace. Easy to do at alignment.
-Robert
Old 07-08-2019, 06:30 PM   #3
Am I incorrect with ball joints containing a hard plastic socket to hold a machined ball so the two are always in contact with some grease for lubrication? Heating the ball joint may melt grease and plastic socket, deforming it prematurely. Perhaps heating meant to loosen to the lockout?
Old 07-08-2019, 07:47 PM   #4
billr
I think the OP said the tie-rod was heated, not the tie-rod end.
Regardless, heating suspension parts for any reason should not be necessary; and would worry me. How hot did they get it, enough to weaken it? There is no way to tell now without getting a bunch of hardness tests on it.
Old 07-08-2019, 08:11 PM   #5
That rod is not hardened.
Old 07-08-2019, 08:20 PM   #6
billr
Do you mean heat-treated? So what, it probably is cold-worked, but maybe not anymore where it was heated.
Old 07-08-2019, 10:55 PM   #7
prioris
I am in central florida.
it just makes me suspicious of the place that did the alignment since I never heard of it. I don't know exactly what "heated tie rod" really means.
they found my front left wheel bearing defective ... I haven't fixed it yet but need to tomorrow I notice it correlates with symptoms of increasing noise as speed increases so assume what they say is true being suspicious of the place makes me wonder if they damaged it i'm taking long trip to maine so want to make sure car is in good enough shape
Old 07-08-2019, 11:13 PM   #8
They used heat so they could get the TIE ROD end jam nut backed off and adjust the toe. This is a standard procedure for convincing a stuck jam nut to release.
Old 07-09-2019, 03:38 AM   #9
prioris
OK Thank you OldNuc
Old 07-10-2019, 04:43 PM   #10
Saturn Night
Translation: "Your outer tie rod and the respective threads were seized and they had to heat the tie rod end in order to get the alignment within O.E. Specifications."
Tie rod and the shaft are both steel, and the rust over time. This causes the tie rod to seize, hence why they had to heat the shaft.
Doesn't make sense to me Mister_Cee S-Series General 13 06-13-2016 12:54 PM
does this make any sense saturn20 Vue Red Line 8 01-22-2012 02:20 PM
Does this make sense? (long) DeCaff2006 S-Series General 21 07-01-2006 02:36 PM
Consumer Reports .. Can anyone make sense of it all ? saturnfreak01 L-Series General 6 11-12-2003 04:35 PM
