Old 04-20-2020, 07:51 PM   #381
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default Re: 1996SL11.9L's 2002 SL1
Originally Posted by Cheyne View Post
I had that same Stant failure last fall.
I know everyone here says Stant only. However, this is the only repair I do repeatedly. Itís annoying. So, Iím doing something different and made in Israel is far better than China or the other cheep parts countries.
Old 04-22-2020, 05:25 PM   #382
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
^^^ yep, I installed a made in China Stant on my '93 Saturn, which worked great
for about two years. Then started running cooler.
I have the made in Israel, Murray thermostat installed in my '99, about year and a half, functioning great so far.
I have the original housing set aside just in case a made in Germany Stant makes an appearance
1999 SL2 A4 -96k miles
Currently sipping Mobil 1 + Delvac 1300 + LM2009 + Rislone
3 ounces Lucas UCL per fill-up
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 05-14-2020, 10:00 PM   #383
1996SL11.9L
2002 SL1
The reman AC compressor I installed last spring just had the clutch fail. Just like my factory one did. Itís out of warranty.
I guess Iím going junking soon. Iím not spending another 400 on a compressor.
Old 05-15-2020, 06:41 AM   #384
454cid
I don't think any Stant is made in Germany unless they're getting thermostats from a German company for specific German car applications.
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 05-24-2020, 12:45 PM   #385
1996SL11.9L
2002 SL1
On the 4Runner Fourm I belong to a bunch of people have ended up with counterfeit NGK spark plugs.
I looked at the Dual ground plugs in a double platinum and they seem to be legit.
Itís time to change out those EK heat range 6 plugs. They have around 60k miles on them now. I put the Denso equivalent in my wifeís outback.
I almost but the platinums in the Subaru.
Now that itís warm out Iím getting 43mpg for work taking the city route. I can drive 30-35mph in 5th gear. It helps a lot.
Iím also starting to see coolant weep out the headgasket area of cylinder 4.
Old 06-22-2020, 08:58 PM   #386
1996SL11.9L
2002 SL1
A friend of mine retired his 2001 from the rear drivers side suspension rust.
I got the AC compressor off of it. It pulled 30Ēhg almost instantly. Left it on for over an hour, checked for leaks and charged it.
I got AC again.
Old 06-24-2020, 01:37 PM   #387
I got AC again.
Nice. You've had quite a bit of woes with compressors, iirc.
Went to use mine the other day, was a nope. Put the gauges on, pressures are normal - clutch is not engaging even with low pressure safety switch jumped. Sigh . . . 90F + and humid last week.
glad to be working from home
Was it a common source or were they showing up in random places?
Old 06-28-2020, 08:32 PM   #388
1996SL11.9L
2002 SL1
It seemed to be both eBay and Amazon. I bought the double platinum 6EK dual ground plugs and they look legit. I have over 50k on my regular 6EK plugs and itís time to swap them out.
Sounds like your clutch gave out.
Old 08-19-2020, 07:22 PM   #389
1996SL11.9L
2002 SL1
I finally changed the spark plugs.
They had 60k miles on them. They were eroded to around .055 gap.
File Type: jpg 02B92D42-102A-4DE8-A9FE-DFF563912122.jpg (137.6 KB, 5 views)
Old 04-13-2021, 07:20 AM   #390
1996SL11.9L
2002 SL1
So, recently Iíve been having TPS issues. AKA after driving awhile the position at idle wonít be zero anymore. Stoping and starting it would put it back to 0 again. That sensor was aftermarket and was installed the weekend I bought this car a few years ago when this thread was started.
So, I put in a Autozone TPS and all was good for around 3 months. Then I bought a BWD from advanced auto and three months now itís doing the same thing. Started this mornings 25 mile drive to work and by the halfway Mark it drifted up to a 3 at idle. It eventually ended up at 5% at idle and pulling back on the throttle bellcrank made no difference. I canít find anything wrong with my throttle body mechanically. Are all aftermarket TPSís crap now?
I guess itís time to go junking and look for a few OEM ones.
Now that itís above 50 degrees Iím averaging 45mpg for my tank.
To be continued.
Old 04-13-2021, 11:08 AM   #391
billr
If you want to spend $5 to mail them to me, I will disassemble/inspect to see if they are really bad or you are throwing TPS units at a wiring/PCM/linkage problem. I can't guarantee an absolute verdict, but am will to give it a try. Send PM if interested.
Old 04-13-2021, 12:47 PM   #392
1996SL11.9L
2002 SL1
Thanks for the offer. I guess I could do that too.....instrumentation is part of my job.
Iíll ohm it cold and hot this off stretch. It still is linear from idle to WOT. It just seems to build some resistance with heat.....
2002 sc2 b.c.m. piperpilot S-Series Tech 2 11-12-2014 09:34 PM
2002 sl 1 Dee631 S-Series Tech 1 11-04-2014 05:36 PM
2002 SC2/Metra 70-2002 stereo harness issue Kai S-Series Tech 4 12-14-2008 03:41 PM
2002 SL1 Help Please reddragonflys20 S-Series Tech 9 11-21-2006 04:26 PM
2002 Sc2 Sps mle S-Series General 1 07-02-2005 07:33 PM
