Old 04-01-2014, 10:51 PM   #1
saturnsl1dohc
saturnsl1dohc is on a distinguished road
Default 1995 Saturn engine swap questions????
Hello, I recently swapped a 1995 dohc engine into a 1995 dohc car. It runs and drives but runs rough. I do understand you need to swap ecus, but my car had the pink plug ins and my dohc ecu has the blue plug ins and they do not plug in. looks right but the ribs are not in the right spot on the plugs. Also, why does the gauge cluster need to be swapped from the dohc? And someone said the fuel pump should be from the dohc also? Please help me out. Thank you in advance!
saturnsl1dohc is offline   Reply With Quote
Old 04-01-2014, 10:55 PM   #2
billr
Default Re: 1995 Saturn engine swap questions????
Was there a typo in there? A '95 DOHC engine into a '95 DOHC car shouldn't be much of a problem. Was the trans changed from manual to auto (or vice-versa) at the same time, is that the real difference?
Old 04-01-2014, 11:01 PM   #3
saturnsl1dohc
Whoops im sorry the dohc engine went into a sohc car. Both vehicles are Manuel Trans. sorry lol
Old 04-02-2014, 12:04 AM   #4
Team327
Team327 has a spectacular aura aboutTeam327 has a spectacular aura about
2003 ION-2 Sedan
1993 SW2
did you swap transmissions too? The dohc trans is geared differently than the sohc trans.
Team327 is offline   Reply With Quote
Old 04-02-2014, 12:34 AM   #5
Need a '95 DOHC PCM to run a DOHC engine.
If automatic, you have to change it to the MP7 (dohc automatic) if you wish gears other than P and N to work.
Trimming the anti-idiot tabs on the PCM connectors only works on compatible years (probably a nicer name for those silly things but I like that one ) using other than a '95 PCM is not a compatible with '95 year.
Old 04-02-2014, 07:35 AM   #6
saturnsl1dohc
as stated, both cars are 95s. I will trim idiot tabs n see what happens. But why does the cluster need to be swapped? And the fuel pump?
Old 04-02-2014, 09:21 AM   #7
Because the DOHC markings goto 130mph and nearly 8k rpms in the same space the SOHC's goto 110 and 7k (even that high?) rpm. The clusters are "dumb" '91-'99, they receive a voltage to move the needle's and the DOHC's expect to be showing a different value than the SOHC's for the same voltage.
No reason to change the fuel pump, but keep the DOHC injectors with the DOHC. Not keeping the DOHC injectors with the DOHC will burn valve's due to lack of fuel because the SOHC injectors don't flow enough to feed a DOHC.
1997 To 1995 Engine Swap KingRex S-Series Tech 2 06-30-2011 11:20 PM
1995 SL1 engine swap BigBrian S-Series Tech 2 12-15-2010 10:26 PM
1994-1995 engine swap question hrtatack1 S-Series Tech 3 04-07-2008 01:04 PM
Engine 1995-2001 SW1 Swap SaturnWagon S-Series Tech 5 05-05-2006 04:10 PM
1995 sc1 engine swap? chaz70 S-Series General 1 10-11-2005 10:21 AM
