Old 06-04-2012, 11:42 AM   #1
arrfenwoof
arrfenwoof is on a distinguished road
1998 SL
Default Answer as to why my SL burns massive oil and sounds like a go-kart?
Well, first day of driving this car to town. I went about 34 miles and it burned... What looks like 1/2 a quart of oil? When driving up a hill, I have to downshift TWO gears to make it up the hill... And the car sounds like a go kart!
The car told me to shift into 5th, so I obliged... And the car started hopping, sputtering and sounded like a go-kart about to stall! So I downshifted and all was fine.
Not sure what is up with this car... But now i'm wishing I never bought a Saturn. They don't feel safe at all on the road.
1998 Saturn SL 5speed 202K mi/325K km
Burns an average of 1 quart per fifty (50) miles. and has many other issues >.>
arrfenwoof is offline   Reply With Quote
Old 06-04-2012, 12:00 PM   #2
Default Re: Answer as to why my SL burns massive oil and sounds like a go-kart?
201k miles?
1-Replaced the original round nosed plastic coolant sensor with a flat nosed brass one? Rich running @1/4 needle temperature is one tell tale indication. Replacing the old thermostat with a new 195F one will help too.
2-Plugged catalytic converter? Remove the front O2 sensor for a LOUD drive; renewed power means a plugged catcon.
3-Low compression? A compression test will tell.
Old 06-04-2012, 12:04 PM   #3
the_whitey87
the_whitey87 is on a distinguished road
pcvs are cheap too
the_whitey87 is offline   Reply With Quote
Old 06-04-2012, 12:16 PM   #4
arrfenwoof
1998 SL
I honestly do not know what has or hasn't been replaced on this vehicle, as i've only owned it for 1 day. Nor do I know where I would find this "plastic coolant sensor", the front o2 sensor or the pcv. How much does it cost for a compression test? Will any of these solve the 50 miles per quart problem?
Old 06-04-2012, 12:18 PM   #5
arrfenwoof
1998 SL
I should mention that the temp gauge is indeed at 1/4.
Old 06-04-2012, 12:21 PM   #6
the_whitey87
Unknown if it will fix these problems until they are tried....use the search function its a great tool in the forum for information like where to find your plastic temp sensor and how to test for a plugged catalytic converter with the front o2 sensor, etc etc. Its a bit of a learning curve but hey, knowledge is money..the more things you can elimenate the better.
As for a compression test...these are very easy to do yourself and you can buy a compression tester kit at a local parts store for probably about the same as what you will pay to have it done. Than you have one (and the knowledge to use it)
TIP---get yourself a repair manual. Huge help.
Old 06-04-2012, 12:23 PM   #7
awilson506
awilson506 will become famous soon enoughawilson506 will become famous soon enough
awilson506's Avatar
1998 SL
Check your EGR valve to. Here is the how to forum with videos and detailed instructions. Get familiar with it, your car has 201K on it
http://www.saturnfans.com/forums/forumdisplay.php?f=26#
R.I.P. 185K 9/17/13
awilson506 is offline   Reply With Quote
Old 06-04-2012, 12:40 PM   #8
PlasticCarsRock
PlasticCarsRock's Avatar
Search 'ECTS' for information about the coolant temperature sensor. As said originally, replace that and the thermostat immediately, and check the cat. That will most likely take care of the drivibility concerns. If that doesn't help, check the EGR valve, and do a compression test.
A functioning ECTS and thermostat may slow the oil consumption a bit (reaching proper operating temperature allows the pistons to expand slightly, and the rings to seal better), however, it sounds like you have a leak or very worn out oil control rings. Many leaks are relatively easy to fix. The cam cover is the most common source of leaks, so check there. If it's the rings, you're in for a full rebuild or a junkyard engine.
Old 06-04-2012, 12:45 PM   #9
arrfenwoof
1998 SL
I don't believe it's a leak, as I don't see any leaks at all. I do smell oil burning and smoke out of my exhaust though.
Old 06-04-2012, 12:52 PM   #10
homiemitchell
homiemitchell is on a distinguished road
head gasket could be gone?
homiemitchell is offline   Reply With Quote
Old 06-04-2012, 01:14 PM   #11
KingRex
KingRex will become famous soon enoughKingRex will become famous soon enough
KingRex's Avatar
Time to learn how to work on your own car it sounds like. It's useful to know.
If you need tools, go buy a 50 dollar kit at any autoparts store and it'll have everything you need.
Coolant Temp Sensor replace:
http://www.youtube.com/watch?v=cucm7QGlsYs
EGR Cleaning:
http://www.youtube.com/watch?v=bt5lRTt6BsU
O2 Sensor Removal for Plugged Cat test:
http://www.youtube.com/watch?v=ju7Znf3Z01A
Watch and learn!
As for the oil burning; Get used to it. Carry a couple quarts with you. All Saturns burn oil.
I drove down to a Convention in Atlanta a couple months ago, from South East Wisconsin. Used 3 quarts there, and back, so 6 quarts total on my trip.
"The Homecoming King"
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
1999 SL2 Silver 125K
KingRex is offline   Reply With Quote
Old 06-04-2012, 03:17 PM   #12
racinginblood
racinginblood will become famous soon enough
racinginblood's Avatar
1998 SL1
wekk king rez not all saturns ive had 2 motors and not one burns a drop at all highway kms around 1200a week infact when i pulled the head on the spare which leaked antifreeze externally and had 220000kms on it the cylinder walls still have the crosshatching marks on the sleeves.ive driven by alot of saturns and havent seen one that smokes yet out the tailpipe
racinginblood is offline   Reply With Quote
Old 06-04-2012, 04:02 PM   #13
KingRex
KingRex's Avatar
As have I. The oil burning is more common than not. My SL1 seems to not be using any at all so far.
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
Old 06-04-2012, 05:58 PM   #14
Spaghettiohead
Spaghettiohead is on a distinguished road
These guys know what they're talking about, so I'd listen up for sure. One thing I can say though, is that road conditions dictate when to up shift, not that shifter idiot light...
Spaghettiohead is offline   Reply With Quote
Old 06-05-2012, 02:54 PM   #15
arrfenwoof
1998 SL
I understand the light, which is why I don't use it I shift around 3k rpm depending on road conditions, obviously. The car just feels... Like the previous owner shifted at 7k rpm the entire life of the car and that is why the engine probably needs a rebuild. I wish people would take care of their cars and just treat them kindly!
Old 04-09-2021, 05:01 PM   #16
Freyakan
Freyakan is on a distinguished road
Does it sound like a go kart.
Freyakan is offline   Reply With Quote
Old 04-09-2021, 07:24 PM   #17
Ricketts
Ricketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of light
2000 SC1
Did you test drive it before buying it?
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 04-09-2021, 08:23 PM   #18
Waiex191
Waiex191's Avatar
It's a 9 year old post. Freyakan is a spambot that hides links in the period of his sentence. I've reported its 4 posts.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 04-09-2021, 08:25 PM   #19
Ricketts
2000 SC1
Yep, crap, should have noticed that. Tired of the spam here, it does get carried away eh?
I need, go-kart or mower seat the_skin_eater Classifieds 0 07-04-2006 12:28 AM
booyah! my saturn go-kart goodness is back! sPuddingTime S-Series General 1 06-23-2006 04:00 AM
Massive corrosion, massive problem. Luigi Mario S-Series General 10 06-03-2006 11:21 PM
95 burns oil kethomps S-Series General 16 06-03-2005 08:24 AM
Did you say your car burns some oil? ym42 S-Series Tech 5 04-19-2005 10:55 AM
