Old 05-28-2012, 04:52 PM   #1
alfasteve
alfasteve is on a distinguished road
alfasteve's Avatar
2002 SC1
Default SC1 won't stay running
Sorry if this is redundant, I posted it in the wrong place.
I have a 2002 SC1 which has had some charging problems. I had previously replaced the alternator, but that did not improve the situation. If I jump it from my other car it starts easily, however, when you remove the jumper cable it stalls immediately. Are there any other sources of charging problems other than the alternator, i.e. fusable links or relays, or anything else to consider?
Any suggestions are appreciated.
Steve
alfasteve is offline   Reply With Quote
Old 05-28-2012, 05:58 PM   #2
Default Re: SC1 won't stay running
There is a fusible link between the starter and alternator, which provides the connection that charges the battery. If that link has failed, and the battery is weak/dead, this will happen. Also check the battery cable connections.
Old 05-28-2012, 06:09 PM   #3
Highmile
Highmile's Avatar
Also check the battery. If it has a dead cell it can cause the same type of problems.
Highmile
'95 SL1 484k and counting
Old 05-29-2012, 06:45 AM   #4
alfasteve
alfasteve's Avatar
2002 SC1
Is the fusable link between the starter and alternator in the green wire connecting between them?
Thanks
Steve
Old 05-29-2012, 09:08 AM   #5
It is the wire connecting them.
SC1 Won't stay running alfasteve L-Series Tech 1 05-29-2012 03:18 PM
91 sc won't stay running medwards22 S-Series Tech 24 05-05-2009 02:52 PM
Help! L200 Won't Stay Running.. tfmc369 L-Series Tech 3 06-07-2007 02:14 PM
Starts but won't stay running Paulapoohcarr S-Series Tech 8 09-23-2005 08:11 PM
car wont stay running pkuptrk Miscellaneous Tech 1 01-04-2003 11:06 PM
