Old 04-10-2021, 06:54 PM   #6801
Kaervak
Kaervak has a spectacular aura aboutKaervak has a spectacular aura about
Kaervak's Avatar
Default Re: What did you do to your S-Series today...
Nothing today, but over the past couple weeks.......
Finished running all new nicopp brake lines from the master cylinder to each wheel. Replaced all the original brake hoses with Goodridge braided stainless steel hoses. New rear wheel cylinders, shoes and brake hardware. Put in a new thermostat since the car was running 20F colder than it should be and got a fresh change of coolant as well. Found out where my oil is going to, the pan is leaking and needs to be resealed. I always thought it was a typical oil burner, not so much apparently. And finally, gave it a nice sudsy pressure washing. Next up is a windshield replacement since the OE one is really chipped up and getting hard to see out of.
Kaervak is offline   Reply With Quote
Old 04-14-2021, 01:54 AM   #6802
Bob243
Bob243 is on a distinguished road
Bob243's Avatar
1991 SL1
Finally started my cradle swap on the 91.
Bob243 is offline   Reply With Quote
Old 04-14-2021, 02:35 AM   #6803
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
1999 SW2
What in the world is holding this thing together
'97 Saturn SL2 @ 146k (M. swapped) - In storage, awaiting an engine rebuild
'99 Saturn SW2 @ 92k (M. swapped) - Daily Driver
r/Saturn_Cars moderator
jpsuli is offline   Reply With Quote
Old 04-14-2021, 04:26 PM   #6804
Bob243
Bob243's Avatar
1991 SL1
Not much, Pretty much why I kept it under a cover for the last few years until I could build myself a proper place to work on it.
Old 04-15-2021, 09:50 PM   #6805
Bob243
Bob243's Avatar
1991 SL1
New cradle in place
Old 04-15-2021, 10:50 PM   #6806
454cid
New cradle in place
Very Nice!
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 04-18-2021, 10:31 PM   #6807
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Changed out the front bumper badge.
The original certainly changed color over the years...
A2Saturn is offline   Reply With Quote
Old 04-19-2021, 01:15 PM   #6808
Hiisi
Hiisi is a jewel in the roughHiisi is a jewel in the roughHiisi is a jewel in the rough
Hiisi's Avatar
I have new tires installed. And it was painful for my budget
Hiisi is offline   Reply With Quote
Old 04-19-2021, 01:18 PM   #6809
Hiisi
Hiisi's Avatar
Looks scary! Mine was way better when I decided it is time to replace.
Old 04-20-2021, 06:37 PM   #6810
ZedNielsen
ZedNielsen is on a distinguished road
What did I do to my S-Series today?
I had to replace my tires, as they were already worn out. I ordered a new set from 4WheelOnline, and all of it arrived in no time.
ZedNielsen is offline   Reply With Quote
Old 04-21-2021, 06:50 PM   #6811
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
Drove my 95 Sw2 to do some errands.
Going to finish the headliner soon, and also turn up the boost on my 95 Sl2 this weekend.
1994 Sl2 5spd First Car, Stock: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd: Retired Daily, Not Stock: 192,000
1998 Sl2 5spd: Family Car, Stock :135,000
1995 SW2 4spd: Daily, Stock: 91,000
Old 04-22-2021, 02:07 AM   #6812
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Adjusted the parking brake cable yesterday. Was getting to the point I could barely hold the car on hills and I knew I had the adjustment nut pretty high up. Tightened the nut and it holds the car well for now. I'm hoping that it was just going through some new cable break-in stretching and doesn't continue to get worse. They aren't exactly the easiest things to change. (Although, I suppose I would get pretty good at it if I have to do them every couple years )
97 SL2, auto, 123K miles
Old 04-24-2021, 06:55 PM   #6813
Zeebins
Zeebins's Avatar
Had to change my phone mounting area to better suit my new phone. I was using a pop socket with my old phone and actually grew to really like them for holding and mounting onto things, like in the car. I tried using a pop socket with my new phone, but it’s actually a little smaller than my previous one. (iPhone 7 - iPhone 12 mini) Trying to use one actually made the phone harder to use. I also wouldn’t be able to easily use the built in magnets for charging/mounting so it kinda worked out anyway.
Got this this wall mount puck off Amazon that blends into the console really well. Had my pop socket mount between the seat and console to make it a little easier to pull in and out without looking. The magnets are way easier to line up blind so I can put it in front of the seat now where it makes more sense. I also decided to try out a magnetic vent mount for GPS use. I couldn’t use them before due to the weight of everything pulling the vent too low. Putting the phone at an unusable angle. That still happens, but my temperature gauge getting in the way actually turns into a benefit. 90’s car vents definitely weren’t designed to hold smartphones, but this works pretty well. Vent mounts also have the bonus of blowing A/C directly onto your phone instead of baking in the windshield.
Old 04-30-2021, 08:31 PM   #6814
Waiex191
Waiex191's Avatar
I let my registration expire.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-01-2021, 12:11 AM   #6815
Bob243
Bob243's Avatar
1991 SL1
Changed the driver side mirror on my sisters 02 SC2 (she has on street parking ) Only took a few min.
Old 05-01-2021, 12:17 AM   #6816
Ditto, couple of days ago, forgot about it until I saw your post. Cut insurance several months ago and forgot about the expiration cuz cant renew without insurance
Old 05-11-2021, 04:58 PM   #6817
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Finally got an alignment at KalTire for the SL. Finally got tired of having the steering wheel canted 15 degrees to the left while driving. Dude said the car felt a bit spongy but I haven't noticed anything. It certainly wasn't as bad as before when the car was nearly undriveable.
Goggles Pisano is offline   Reply With Quote
Old 05-11-2021, 11:48 PM   #6818
cgg17
cgg17's Avatar
1995 SW2
Took the 95 sedan out for a drive and filled it up, 7lbs is much quicker than I expected. Getting the 95 wagon ready to haul two engines home next weekend.
Old 05-14-2021, 02:54 AM   #6819
454cid
Today was new air filter day. The old one wasn't terrible. I don't drive through much dust, and I can go years without really needing one, but I found it on Wholesale Closeout on Rockauto, so why not? It's another Champion Labs, but arrived in their Luberfiner brand.
1999 Chevy K3500
Old 05-14-2021, 11:48 AM   #6820
SRGW
1997 SL1
Post Re: What did you do to your S-Series today...
Changed oil and filter 1997 SL1. Out Walmart Synthetic 10w30 and Purolator 20195. In Walmart Synthetic Blend 10w40 and Purolator 20195.
1995 SL1 236,300 2005>2018
1997 SL1 89,412 2014>????
CHECK YOUR OIL!!
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
