Old 06-06-2007, 09:37 AM   #1
tfmc369
tfmc369 is on a distinguished road
Default Help! L200 Won't Stay Running..
my wife has a 2002 or 2000 l200..
34k mileage
2.2 liter engine
she went to start it yesterday and it was completely dead.
tried jumping it and it turned over, but died after about 2-3 seconds.
took the battery out and got it checked. it came back replace battery..
bought new battery & replaced it the next day. the car started and ran for about 3-4 seconds and died again.. everytime it starts, it runs for about 3-4 seconds and dies..
is it the fuel filter, fuel pump, alternator?
has ne1 else had this kind of problem?
any help asap would be greatly appreciated.
thanx in advance
The Fishman
tfmc369 is offline   Reply With Quote
Old 06-07-2007, 11:43 AM   #2
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default Re: Help! L200 Won't Stay Running..
I had this problem in a 1990 Accord. Turned out to be the wiring harness that goes from the ignition switch down the steering column. Strange, but that was the problem.
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
spencerb is offline   Reply With Quote
Old 06-07-2007, 02:07 PM   #3
Your security light isn't on is it? I would guess in order of increasing difficulty the fuel pump relay then the fuel filter. After leaving the ignition key in the ON/RUN position try depressing the fuel rail schrader valve (cover with a rag and expect a healthy spray of fuel) for fuel spray. The fuel pump only runs for 2-3 seconds with the ignition on w/o the engine running, long enough to prime the fuel lines. No fuel spray may indicate a faulty fuel pump relay. A healthy spray means at least fuel pump and pressure is available for starting. Its running that seems to be the problem and can be the same fuel pump relay, the crank position sensor, and the fuel filter restricting fuel flow. When the engine runs the CPS will continuously generate signals to allow the ECM to run the fuel pump, ignition system and injectors.
Old 06-07-2007, 02:14 PM   #4
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
same problem I had a long time ago.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Robman is offline   Reply With Quote
Daytime Running lights stay on? Mr. Callaway L-Series Tech 12 04-16-2014 05:28 PM
91 sc won't stay running medwards22 S-Series Tech 24 05-05-2009 02:52 PM
Starts but won't stay running RickD. S-Series Tech 10 04-08-2008 09:26 AM
Starts but won't stay running Paulapoohcarr S-Series Tech 8 09-23-2005 08:11 PM
92 Saturn SL1 won't stay running help please Hannah21 S-Series General 3 02-23-2005 11:36 AM
