Old 09-03-2019, 01:53 PM   #301
Default Re: S-Series Swap Guide
Axles:
http://www.saturnfans.com/forums/new...te=1&p=2295439
Originally Posted by PlasticCarsRock
From the factory, they are different, but the only difference is that the ABS axles have a reluctor ring (like a gear) for the wheel speed sensor.
As such, a non-ABS axle cannot be used on an ABS vehicle (the ABS wouldn't work), however, an ABS axle will work fine on a non-ABS vehicle.
There is a good chance many if not all aftermarket axles have the ABS reluctor ring (that way they don't need to make two different parts).
Originally Posted by OldNuc
The 91-93 axle does not swap into the later cars due to different splines on the outer CV hubs.
--The inner axle joint splines are the same from 91-02.
They will all fit into your transmission or onto your intermediate shaft regardless of trans type or brake equipment
--The axle shaft itself is 23mm thick for 91-93. It is 24mm thick for 94-02.
This goes for ALL the axles. ABS made no difference here.
The outer CV joint is where the most debate seems to happen.
--91-93 has a smaller spline diameter requiring the 91-93 wheel hub when using these.
--The 94-02 have a larger spline diameter, requiring the 94-02 hub.
Axles are not transmission specific. They are the same whether auto or manual transmission.
Generally, the right (passenger) axle for cars that came with steel wheels is the one most likely to break. These came with a rubber balancer to dampen vibrations on that side, apparently. Water and salt tends to collect under this, weakening the axle. If pulling from a junkyard, grab an axle from a car that came with alloys that does not have this ring. I never noticed a difference
see post 5 for how to select a good JY axle
http://www.saturnfans.com/forums/sho...d.php?t=137511
Old 12-12-2019, 07:55 PM   #302
97SL2guy
97SL2guy is a jewel in the rough97SL2guy is a jewel in the rough97SL2guy is a jewel in the rough
2006 ION-2 Sedan
I'm curious about Ignition Control Modules for my 97 SL2 DOHC. Any idea what years and models will interchange, or pretty much most of them?
GM Parts Pros site shows the OEM number for my car is 19178836 but if you scroll down, this number also fits 98-02 SC1's (no mention of any other SL cars!). Weird. But not to out of the question since the one I picked up from the junkyard the other day was indeed off an SC1.
I'm just curious if the ignition module from pretty much ANY SL2 will interchange and have the same pins.
Thanks.
97SL2guy is offline   Reply With Quote
Old 12-13-2019, 09:06 AM   #303
trottida
trottida's Avatar
Yes, same ICM for 96-2002 S Series all models (coupe, sedan, wagon, DOHC & SOHC). 91-95 uses a different ICM.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 08-20-2020, 01:33 AM   #304
spettro9
spettro9 is on a distinguished road
spettro9's Avatar
2001 SC1
Bumping:
I'm about to put a junkyard engine I rebuilt in.
Is it possible to drop it in with the intake manifold already on?
I think it is, right? but I'd like to hear from some who have done it.
I know I can put on later too.
Gonna keep exhaust manifold off til it's in.
Edit:
Answered my own question. (Intake can go on first.)
https://www.youtube.com/watch?v=DMLHtU5J4qg
(cool music too.)
2001 Silver SC1, from craigslist in Clifton, NJ 2011/01/21, with 70k miles, $3K,
27 normal (winter 25 mpg) / 37-40 highway
(just have to watch oil a bit... seems to be 3/4 qt in 1000 miles, )
spettro9 is offline   Reply With Quote
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
i know theres the engine swap guide, but... KawaiiBoricua S-Series Tech 7 03-18-2008 08:00 PM
i read the swap guide lowwSC2 S-Series Tech 17 01-07-2008 11:57 PM
Swap guide richamer1 S-Series Tech 8 12-05-2007 11:01 PM
what happened to the swap guide 94503 S-Series General 1 05-14-2007 07:43 PM
