Old 06-12-2012, 01:37 PM   #1
saturn hippie
saturn hippie is on a distinguished road
Default Metal tapping sound after rebuild
Did a rebuild on my 2001 SOHC (new rings, pistons with oil drain holes, crank, bearings, seals) and started it up for the first time. There is a tapping noise that almost sounds like valve tap (i am unsure on this). Cylinder #3 has low compression. Any thoughts on what the issue might be? My first thought was that i am going to have to pull the head back off to inspect the cylinder itself, but i wish to avoid that if possible.
saturn hippie is offline   Reply With Quote
Old 06-12-2012, 01:43 PM   #2
ahimsa1
ahimsa1 is on a distinguished road
1997 SW1
Default Re: Metal tapping sound after rebuild
What did it sound like and how was the compression before the rebuild?
Did you do any work on the head or valves, or did you just take the head off and put it back on unchanged?
97 SW1 Auto 174k
ahimsa1 is offline   Reply With Quote
Old 06-12-2012, 01:52 PM   #3
saturn hippie
Replaced the valve seats and had the head cleaned and shaved .003/inch. Compression before the rebuild was fine, until the connecting rod bearings seized which prompted the rebuild. The tapping sound almost sounds like the piston is hitting something it shouldn't. The sound gets more intense when the engine is revved above idle.
Old 06-12-2012, 04:08 PM   #4
ssewall
ssewall is on a distinguished road
Collapsed lifter?
It's common for the lifters to take a while to pump up right after a rebuild. It should go away after a few miles though.
ssewall is offline   Reply With Quote
Old 06-12-2012, 09:12 PM   #5
Highmile
Highmile's Avatar
Check the location of the rocker arms on cylinder #3. It's easy to get them off of the valve. If they look ok then check the lifters.
Good Luck
Highmile
'95 SL1 486k and counting
Old 06-13-2012, 06:44 PM   #6
saturn hippie
Pulled the lifters out. The ones on #3 were collapsed so i just replaced them all, took care of the tapping noise.
head, low compression, sohc
2007 Vue making a "metal to metal" sound joe7366 Vue Tech 2 07-24-2011 08:26 PM
Tapping sound on 92 SL2 KingRex S-Series Tech 12 03-29-2008 10:52 PM
metal on metal sound billbat S-Series Tech 6 03-29-2007 09:39 PM
2003 Saturn Ion 2 with metal metal sound BCC Ion Tech 5 11-28-2006 11:32 PM
Brakes sound like Metal to Metal, WTF?!?! TIMSPEED S-Series Tech 12 01-24-2005 03:34 PM
