Old 07-11-2004, 10:00 PM   #1
wayne kobe
wayne kobe is on a distinguished road
Default cooling fan
my 93 sc1 coolong fan will turn on if you turn on the ac but it wont turn on under normal operations what should i check. i had a almost overheating condition.
thanks wayne
wayne kobe is offline
Old 07-11-2004, 10:47 PM   #2
wayne kobe
Default
ok the temp gauge seems to read fine but fan dont turn on but it will turn on if i short the 2 wires in the plug out
wayne
Old 07-11-2004, 10:57 PM   #3
sierrap615
sierrap615's Avatar
Default
possible bad ECTS
year?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 07-11-2004, 11:06 PM   #4
amazinghl
Default
It is not suppose to turn on under "normal operation"
What do you mean by "overheating condition"? Does it mean your needle almost in red zone?
00 Insight 72mpg
amazinghl is offline
Old 07-11-2004, 11:14 PM   #5
wayne kobe
Default
needle well above 1/2 way fan wont come on but comes on like it should if you turn on ac or jumper the ect plug
wayne
Old 07-11-2004, 11:26 PM   #6
wayne kobe
Default
wayne
Old 07-12-2004, 12:01 AM   #7
amazinghl
Default
Change the ECTS.
00 Insight 72mpg
Old 07-12-2004, 12:28 AM   #8
ExNihilo
ExNihilo is on a distinguished road
Default
Yeah, bad thermostat. The fan is set to always be on when the A/C is on, so it doesn't depend on the thermostat for that. Is "ECTS" the full designation for thermostat? I guess probably.
ExNihilo is offline
Old 07-12-2004, 12:31 AM   #9
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Definitely should install the updated ECTS in it. If you already have the newer brass version, then that is probably not the issue. I'ts also possible that this is normal. Older Saturns have always gotten real hot on the gauge before the fan kicks on. I think they later updated the gauges so people wouldn't worry as much. Try just letting it idle on a hot day and see if the fan kicks on by itself and cools it down with the temp gauge gets to the red. If not definitely something going on.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Applefool is offline
Old 07-12-2004, 01:19 AM   #10
jeep4523
jeep4523 is on a distinguished road
Default
Also....fans don't kick in untill 3/4 temps.
Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a well armed sheep contesting that decision.
jeep4523 is offline
Old 07-12-2004, 01:20 AM   #11
amazinghl
Default
No, ECTS is stands for Engine Coolant Temperature Sensor.
Thermostat does not communicate to anything.
00 Insight 72mpg
Old 07-12-2004, 02:09 AM   #12
sierrap615
sierrap615's Avatar
Default
thermostat is the spring loaded thing by the water pump that when the right temp is reached, opens and flows fluid to the raditor
the Engine Coolant Temperature Sensor(ECTS), in the head, is a small sensor that tells the PCM the coolent temp. the PCM decides many factiors based on the ECTS, mainly the Air/Fuel mixture, but also when to kick on the cooling fan.
for many years, saturn used a nylon cased ECTS. after a few years the nylon would crack, this lead to false reading, normally that the engine is to cool. the false reading will cause overheating, running rich(along with poor gas mileage and in rare cases clogged cats), ect. the nylon has since been replaced with brass. i have not heard of one problem with the brass ECTS, its a simple, $15 piece, and 100% reverse compatible with the old design.
Old 08-29-2004, 12:50 AM   #13
provoboy10
provoboy10 is on a distinguished road
Default
it could be that your fan motor is going out. mine went out on my 98 SL2 and it wouldnt kick on at all but when i turned the ac on. i ended up over heating reall bad one day and blowing a whole in my side tank with out the fan turning on but when i would turn the ac on the fan would take off going so i took it down and it ended up being that the fan motor had just gone out.
provoboy10 is offline
Old 08-29-2004, 03:13 AM   #14
wolfman
wolfman's Avatar
Default Re: cooling fan
thanks wayne
The 93' has the "Scare the crap out of all the owner's" calibrated temperature gauge. Under NORMAL operation the fan will autoactivate BETWEEN the 3/4 and RED HOT mark and go back off just above or at the 1/2 way point. IF it comes on with the A/C but does NOT activate as described above, the ECTS is likely to blame. It is the TWO WIRE sensor located just below and to the right of where the upper radiator hose attaches to the ENGINE. See the "How To" section for DIRECTIONS and PICTURES on how to locate and change it if need be.
wolfman is offline
Cooling Fan Again richamer1 Ion General 4 10-05-2008 02:06 PM
cooling fan notamechanic L-Series Tech 4 02-25-2007 02:50 AM
AC, cooling fan, and blower fan simultaneously shutdown JamesH S-Series General 1 10-23-2005 04:48 PM
Cooling fan won't come on! GoldenSaturn94 S-Series General 9 09-15-2005 07:02 AM
Cooling fan does not come on.. Rob130 S-Series General 7 03-22-2005 04:36 PM
