#41 |
OldNuc, your motor mounts post deserves a bookmark at minimum. I'm absolutely doing this car properly before that engine even goes in. The other one is going to have to wait (it's too cold out), but at least now I know how to do it right. I bet your car is silent on the inside.
![]() SC2C95Saturn & OldNuc, The diff pin issue will be getting fixed - I don't want to take this engine or transmission out again. I'm a good welder and know even better welders, so thoroughly welding it isn't a problem, but that seems to just prevent it from popping a nice whole through the tranny. Your guys' way of fixing it seems very good. I'll get the transmission disassembled ASAP and fix this little bugger. I'll try to post a nice how to with pictures on this "upgrade". |
#42 |
The top front of the dash top rattles against the windshield in winter on washboard gravel roads. I fixed the window crank handles.
#43 | |
![]() Quote:
![]() So nothing new really just started taking the transmission apart. Is The Right Stuff OK for remaking all the tranny gaskets? All have broken, and I cannot find them anywhere. But the good stuff - pictures! #1 - The only bad spot on the car. Need to grab a junkyard piece and get it repainted to match (or better yet find a green one!). Also, notice the weather stripping below the windshield... That needs bent back down. #2 - The lower block laying out on it's table. #3 & #4 - The crank, totally smooth (thankfully). Still have to get the old bearings back in and plastigage it all. #5 - The only damaged connecting rod bearing (it just fell out during removal of the piston). Belongs to the #1 cylinder(?) - second one over from the timing chain side. That's very likely the sucker that attacked everything in the head. #6 - One of the crank journal bearings - all look like this. ![]() |
#44 |
Paper gaskets must be replaced, not patched. The case halves are sealed with Locktite 518 or Locktite 516.
There are only 2 paper gaskets, end cover and shift selector. Look up part number here: http://parts.nalleygmc.com/default.aspx Order from lowest price+shipping Saturn OEM Parts Source GM Parts Giant- http://www.gmpartsgiant.com/ GM Parts Direct- http://www.gmpartsdirect.com/ Get Saturn Parts- http://www.trademotion.com/splash/in...?siteid=214643 GMparts4U.com- http://gmparts4u.com/ Your local dealers - http://www.partsvoice.com/ The rods must be resized and the crank thrust bearing faces examined for bearing wear and crank measured for thrust clearance. You can drop it in the block with the main caps off and get the clearance on the thrust. No point in spending money on scrap iron. Last edited by OldNuc; 01-19-2013 at 12:11 AM. |
#45 |
Thanks on the PM, that is awesome... well, not the crank part.
Those 2 paper seals would be the ones. And I think I've found them. (for my reference) 21001232 (outer box; fifth gear?) 21001244 (shifter) I'm going to focus on the getting the transmission fully squared away for now. This engine is becoming problematic. Rebuilt Head + New Crank + Re-bore + everything else = May have to raise my debt ceiling. |
#46 |
It has been too dang cold to get anything done lately. There is a machine shop up in Indy that comes highly recommended from a mechanic friend. I'm heading up to talk to them Saturday.
I did get the transmission seals locally - same price as online, sans shipping. 90% done rebuilding the alternator - the one off this car replaced the bad one in my '96. One question, that 5th gear swap with the .605 gear... This is a '95 SC2 with cruise control. Does that mean I can do it and keep cruise control? ![]() ![]() |
#47 |
Yes, cruise will continue to function just fine. Beware that tire diameter becomes a big issue with that 605 OD gear. I posted a chart of tire size vs mph/1000rpm in the 5th gear thread. The 195/60R15 tire is probably about the best choice for use with this gear. More tire diameter than tat will result in a huge RPM gap between 4th and 5th.
#48 |
Sweet!
Tires were also transferred to the '96, so I'll just remember to get that size when replacing them. |
#49 | |
![]() Quote:
Saturns: 1993 SW2 MT 249,000 hard Boston city miles ("Rozzie") Gone but not forgotten: 2001 LW300 ("Elle") 1999 SW2 MT Project cars: 1966 Corvair Monza convertible 1928 Ford Model A Tudor Sedan |
#50 |
@cityhawk,
Yes, I'm definitely going to fix it - just waiting for some warmer weather! ![]() There's a mechanic in my neighborhood who'll probably do the hot tanking for very cheap (I do computer work for him). Finally got ahold of the machine shop today. See how this sounds to y'all: Clean/Bore/Hone/Reclean = $120 (-$60 for cleaning) Grinding crank = $85 Resurface flywheel = $35 Total ~ $180 The head will probably be a J&C rebuilt for $279. Not too bad. |
#51 |
Shop price is good.
#52 | |
![]() Quote:
#53 |
OEM dogbones are expensive and the aftermarket part is substandard. Get a set from a 2000-02 and pull them from the transmission side so hey are not oil soaked. If your engine has a smooth idle then the polly inserts will work well.
21012889 ~55 ea. |
#54 |
Are you sure that's the correct part number? the online parts sites say it's a "BOLT/SCREW-TRANS MT STRUT BRKT" and the price is between $2 and $5.
I tried doing a car-part.com search, but couldn't single out the part. Per this thread, I don't have an upper trans dogbone (and don't know how long it's been missing, since I hadn't taken off my battery box until I replaced the transaxle). My idle is pretty smooth. The car runs beautifully. I was hoping to let my fingers do the shopping for a dogbone, given the difficulty of me getting out to a junkyard to look for one myself, but my attempts thus far have been thwarted.
#55 |
Part number 21013013 -- though the price seems ridiculous (I believe it is the assembly and includes the bracket, so perhaps not the right part number). when looking at diagrams, the actual strut itself seems to be less than that (I'm seeing $54.90 on trademotion.com) but I can't get the part number from it
Saturns: 1993 SW2 MT 249,000 hard Boston city miles ("Rozzie") Gone but not forgotten: 2001 LW300 ("Elle") 1999 SW2 MT Project cars: 1966 Corvair Monza convertible 1928 Ford Model A Tudor Sedan Last edited by cityhawk; 02-01-2013 at 03:15 AM. |
#56 |
Part 9 (and part 5) in this diagram
#57 |
Okay, sorry for the quadruple post, but I believe I found the proper part number in case anyone besides me is curious: 21013105
#58 |
It is a 55 part and is probably not available. Junkyard and polly inserts.
#59 |
Actually, GMParts4U has it, but, yes, it's approx $55.
#60 |
They list everything but deliver less. Go to GM Parts Direct and see if it is listed as available.
Bookmarks |
1995 Auto SL2 DOHC (spun #3) swap or rebuild? | topCONsurveyor | S-Series Tech | 8 | 02-07-2012 02:07 AM |
1.9L DOHC rebuild kit.... | saturn_69 | S-Series Tech | 11 | 11-03-2011 10:22 AM |
1995 SL1 SOHC rebuild? | Solreaver | S-Series Tech | 12 | 09-10-2009 03:04 PM |
1995 SOHC swap to 1995 DOHC | Dreamimage | S-Series Mods | 19 | 01-26-2008 01:54 PM |
'99 DOHC Rebuild | 99_sl2 | S-Series Tech | 6 | 02-13-2007 08:11 PM |
