#1 |
![]() Join Date: Jun 2010
'03 ION 2.2L
Whenever I use A/C or defrost, the radiator fan comes on like it's supposed to, but it always runs at high speed. I've confirmed it's not caused by the two fuses under the hood. What else could it be? |
#2 |
The blower motor resistor has likely failed
Member of the Crank Window Club |
#3 |
#4 |
Are you talking about the rad fan or the blower in the car?
Rad fan on the ION's should only be a single speed one. If it is the blower then as davidsky said the blower motor resistor is the most likely cause.
A lousy day in paradise is still a day in paradise. |
#5 |
they must mean the blower motor, not the radiator fan. the resistor pack, or wiring could cause this.
2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand. |
#6 |
I'm talking about the rad fan. Only single speed...really?? It's clearly running wayyy faster/louder than ever before. My repair manual (Haynes/Chilton) talks about the fan control module using relay(s) to regulate low/high speed with some PCM involvement too. But the manual cops out and basically says to take it to the dealer once you know it's not a fan motor or fuse issue (and I've already ruled those out).
#7 |
Totally missed the radiator fan part, sorry about that. Mine is real loud as well but I'm too lazy/poor to have a look at it.
#8 | |
![]() Quote:
Wiring diagram for the cooling fan only shows one relay. If the rad fan seems noisey check for a damaged fan or blockage in the condensor rad assembly.
Bookmarks |
Wiper only works on High ? help | morris | S-Series General | 5 | 05-07-2010 12:48 AM |
radiator fan on all the time - high speed after cat replacement | slothy | Vue Tech | 6 | 03-25-2010 01:58 AM |
radiator fan operation at high speed | saturnsctwo | S-Series Tech | 1 | 09-07-2005 07:00 PM |
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? | 2k3L300HID | L-Series General | 64 | 03-10-2005 11:53 PM |
woooooooo radiator fan works | freakerz | S-Series Tech | 1 | 06-10-2004 03:00 PM |
