Old 07-10-2007, 07:17 AM   #1
bitz_dv
bitz_dv is on a distinguished road
Default cooling system and stuck gears
I have been reading through the forums here for a couple of months, and its about time I post something. First let me start off by saying that my 95' SC2 was nearly a horror story, the day I bought it I stalled on the expressway and just about every code was popping up, also I found out it was not a 100k car, but a 200k+ as carfax said the odometer was rolled to 0 at the first 100k. So I will be starting a few threads as I get around to things I have problems with that I haven't been able to fix.
My problem today is as follows: Last night I go to change my theristat, get the new (non OEM) 195° one in there, close it up and go to flush the system. I figure I don't have to do too good a job because I just had the system powerflushed 2 weeks ago, anyway the overflow tank fills up, and the water isn't going anywhere, so I start pulling off hoses and what do I find, but a ball of some cotton like substance stuck in the line below the tank, This stuff was everywhere in the sytem, I pulled out all of the hoses and the tank and cleaned them, the tank had a glittery substance in the bottom, like extreamly fine metal shavings, but they felt smooth and didn't cut me when I rubbed them in my fingers. There was also a considerable amount of mud in there. So I put it back together and flush, when I put the 10mm bolt back in the bottom, I find that someone had forced it in at one point and bored out the hole a little, so it wouldn't go straight back in without a fight, I have it in half-way right now, I know not to force it because it is going into alluminum. so...
1. Was this cotton stuff supposed to be in there? What could it be from?
2. What is this sparkly stuff? I'm thinking maybe an additive to help seal?
3. Should I go yell at the guy who did a powerflush, all this garbage in my system, and the coolant is a muddy dark green after 2 weeks.
4. What do I do about the 10mm bolt, the hardware is fine, but if I put it in, it gets stuck and I pull it out, there is metal shavings in the threads, is there a way to get it up in the original path into the block?
Also, When I was all done with this, I started it up and my SES light was off (YES!!) and the thing drove beautifully for about 10 miles, the temp gage got to about half, whereas before it would sit just below this maybe at a third, but the SES came back on, and I started getting stuck in lower gears (this happens when my car is above the 1/3 line, so i usually blast the air anytime I stop or am stuck in traffic) I think it could be my PCM, because of the fact that almost every code in the book poped up the first time my mechanic looked at it, and the trans codes came back speradicly, and it was blowing a 10amp fuse (can't remember wich) in the underhood fusebox everytime I reved the engine too high.
Tomorrow I will do a MMO soak (couldn't find it so I have seafoam, will try AutoZone tonight tho), PVC valve replace, and clean the (EGR?). Also have the Rotella diesel oil (she burns a ton of oil). Thanks to anyone who adds there 2 cents, sorry for the long post, I have so much I need to fix.
bitz_dv is offline   Reply With Quote
Old 07-10-2007, 09:23 AM   #2
DonP
Default Re: cooling system and stuck gears
Silver stuff? Someone in the past dump in some sort of radiator stop leak?
You probably will want to change the ECTS, if it has not been changed already. See the threads in the Hiow-to Library forum.
If it is the original radiator, you can expect the driver side plastic end tank to develop a crack and leak soon, that may explain the stop leak stuff.
Crud in the coolant reservoir is not unusual, cleaning the reservoir is the usual solution. Can't speak to the bolt issue.
Shifting problems. Can you elaborate a bit more?
Old 07-10-2007, 10:07 AM   #3
bitz_dv
Sorry, should have mentioned that I have an automatic first of all. When the engine gets warm (the coolant temp at half) the car will get stuck in lower gears, for example, one hot day I was at a long stoplight, and when I accelerate it got stuck in first gear and my engine got up to 4500 RPM, quite a bit high I think for first, sometimes it will go into second if I let off the gas so the the RPM goes under 3000 and accelerate, most of the time I have to pull off the road, turn off the car, wait a minute to let it cool down a bit (and to reset the PCM) then start back up with AC going to get the fan spinning and it usually will go through the gears just fine for a few mins, unless the temp gets back up. This will happen in first second and third. I think that the PCM is getting bum information and trying to limit me (like a limp mode?) so maybe this is the ECTS since the thermostat replace only worked for like 10 miles.
I used to beat up cars, then I got a Saturn.
-Bitz
Old 07-10-2007, 10:11 AM   #4
bitz_dv
I have only had this car for about 5 months, so I'm not sure, The hoses looked good, and I didn't mess with the bottom tank, I'm not even sure where it is, the guy who had it before me didn't seem to take great care of it, (though it is at 200k plus) the interior was filthy, but it had new tires and a spotless engine when I bought it (the engine is much dirtier now because of burning oil, but no leaks, only the burnt up greasy powdery black stuff everywhere.
-Bitz
Cooling system... SaturnRider S-Series Tech 2 05-15-2008 03:05 AM
Cooling System mk43 S-Series Tech 28 08-25-2007 05:09 PM
Stuck on the cooling fan... zaphod4239 S-Series Tech 11 05-09-2006 12:21 PM
No gears and TCC stuck rockwood S-Series Tech 6 02-08-2005 12:01 AM
cooling system? 30pack S-Series General 3 04-05-2004 11:28 PM
