Old 07-27-2021, 04:04 PM   #1
V3DT
V3DT will become famous soon enoughV3DT will become famous soon enough
Default Torque Strut, Strut to Cradle Bracket & Transaxle Mount to Cradle Nut Torque Specs
I've been googling trying to figure out what is correct.
I've seen 24 ft-lbs for the trans mount into the trans.
the nut on the bottom against the cradle I've seen 27 ft-lb, 35 ft-lb & most seem to say 37 ft-lb...
I was installing a new transmission mount & the stud broke off before the torque wrench ever clicked for 37 ft-lb... So I bought another one, made sure to keep any oil, grease off the threads & torqued to 37-ft-lb again using a different torque wrench, didn't snap so I'm not sure what happen with the first one if the torque wrench just wasn't working right or if the stud was defective or if 37 ft-lbs is just the wrong spec for that??
then the torque strut itself, I've seen 37 ft-lbs & 52 ft-lbs, one page I found on this site says 52ft-lbs if the bolt is 10.9 http://www.saturnfans.com/forums/sho...d.php?t=221441 while another page I found says it's only 52ft-lbs if the bolt is 12.9 http://www.saturnfans.com/forums/sho...d.php?t=208268
mine are 9.8 on the trans side of the torque strut & 10.9 on the body side of it.
So to be safe for now I did 37ft-lbs & also bought a new digital torque adapter so I can double check the torque wrenches are working correctly.
V3DT is offline   Reply With Quote
Old 07-27-2021, 05:15 PM   #2
Default Re: Torque Strut, Strut to Cradle Bracket & Transaxle Mount to Cradle Nut Torque Spec
24ft/lbs for the 10mm bolts into the transmission, 37ft/lbs for the rest.
Old 07-27-2021, 08:03 PM   #3
V3DT
One page I found on here says*
I wish they allowed edits past 15 minutes, I always notice typos later.
That is exactly how I have them right now.
Need Engine Cradle Torque Specs Dustindell 2008 Vue 9 03-30-2015 12:00 PM
Torque Strut Mount Cheyne S-Series Tech 3 05-01-2013 08:54 PM
Front Upper strut mount torque specs 2001 SL-1 msehler S-Series Tech 2 04-14-2013 10:53 AM
engine cradle torque specs? deerslayinrenek S-Series Tech 3 05-28-2011 04:26 PM
Dealer replaced strut, strut mount, and strut bearing tomcatt1 Vue General 17 10-03-2007 04:53 PM
