Old 04-09-2015, 10:38 PM   #1
bankshot
bankshot is on a distinguished road
Default 98 Saturn won't stay running
I have a 98 SL with 133k the fuel gauge was acting erratic for a while, it acts like its running out of fuel.Mechanic said it needed a fuel pump. We had the new fuel pump installed and filter the car ran great for 166 miles then stalled again no codes showing. Any help on what else I could check.it starts but only runs for 15 seconds .
bankshot is offline   Reply With Quote
Old 04-09-2015, 10:46 PM   #2
Default Re: 98 Saturn won't stay running
Try blocking the EGR, Cut up a can and put it between the EGR and gasket. https://www.youtube.com/watch?v=8YRq2Xl58Oo This will check for EGR leakage problems.
Old 04-09-2015, 11:04 PM   #3
bankshot
I replaced EGR and new gasket 6 months ago.
Old 04-09-2015, 11:09 PM   #4
There are other causes of the EGR opening when it should not. The block checks for that. If the EGR opens at idle the car quits running.
Old 04-09-2015, 11:14 PM   #5
bankshot
Ok I'll try that this weekend also I'll be checking tbe fuel pressure
Old 04-09-2015, 11:17 PM   #6
bankshot
If it runs by blocking the egr what's the remedies
Old 04-09-2015, 11:22 PM   #7
Start figuring out why it is coming open. There are several choices and throwing parts at it is expensive.
Old 04-10-2015, 03:18 PM   #8
bankshot
Ok just check fuel pressure 18lbs shouldn't it be at 40
Old 04-10-2015, 03:23 PM   #9
Fuel pressure is 45-51psi, key on engine off or running at idle Use a WIX 33731 filter/regulator. RockAuto will be your lowest cost or possibly Amazon, check both. There is nothing else that works.
Old 04-10-2015, 03:36 PM   #10
bankshot
I change filter/regulator already it didn't fix the issue.
Old 04-10-2015, 03:49 PM   #11
Your post above says you have 18psi fuel pressure. The filter/regulator is what causes this. It is not just some low buck filter, it is also the pressure regulator. If you used a WIX 33731 filter/regulator unit then the fuel pump is the only other answer to low pressure.
Starting multiple threads with the same issue is not going to get this fixed.
Old 04-10-2015, 04:15 PM   #12
bankshot
Sorry about the multiple threads new to the forums I m learning how to navigate it. I'll be installing another new pump this weekend. I purchase and installed a new pump last week I bought from auto parts warehouse.com for $75.00 I guess buying cheap just made my efforts a headache the new pump was 215.00 I'll let u know if this fix's the problem.
Old 04-10-2015, 05:01 PM   #13
Carter makes the only pump that works. Carter P74838M pump assembly and Rock Auto sells them. http://www.rockauto.com
Old 04-10-2015, 10:08 PM   #14
bankshot
I already purchased a airtex fuel pump
Old 04-10-2015, 10:23 PM   #15
Do yourself a very big favor and take it back and order the CARTER unit I posted the part number for. Airtex pumps fail rapidly. You can find that carter pump on eBay for 120.00 Just be absolutely you are actually buying the correct Carter pump unit. Some eBay auctions will sell off brand pumps under the Carter number. Search eBay for this auction number 331167535472
Old 04-11-2015, 02:14 PM   #16
bankshot
How do I keep fuel pump running so I can empty fuel tank, can I bypass fuel relay.
Old 04-11-2015, 04:34 PM   #17
Yes, carefully jumper between pins 30 and 87. I believe 87 has a small + symbol next to the pin on the fuse panel. The pump will run regardless of the key position.
Old 04-12-2015, 02:45 PM   #18
bankshot
Happy Re: 98 Saturn won't stay running
Just letting you all know after changing fuel pump car runs good. Thank for all the help.
Old 04-12-2015, 02:53 PM   #19
A little gas and they run much better.
Old 05-07-2015, 04:00 PM   #20
bankshot
I should have taken your advice Oldnuc that airtex fuel pump failed. Why do these pumps keep failing, this is the third in 3 months.
Tags
won't stay running
Saturn Ion 2.2 won't stay running Anarchy_Nate Ion Tech 6 09-02-2019 03:59 PM
UPDATE: Saturn Ion 2.2 won't stay running Anarchy_Nate Ion Tech 6 12-17-2015 06:44 PM
98 Saturn SL won't stay running bankshot General Saturn Discussion 1 04-09-2015 09:55 PM
94 Saturn SL2 will not stay running moresaturn S-Series Tech 22 05-23-2013 09:59 PM
92 Saturn SL1 won't stay running help please Hannah21 S-Series General 3 02-23-2005 11:36 AM
