Old 01-01-2008, 10:30 PM   #1
MythicalForce
MythicalForce is on a distinguished road
1999 SW1
Default Where is the ATF refill hole?
I accidently drained some ATF fluid thinking it was the oil drain. Now where is the refill hole so I can put back the amount I drained? All I see is the dipstick for the ATF. It's a 99' SW1. Also, which ATF fluid at Walmart should I get?
MythicalForce is offline   Reply With Quote
Old 01-01-2008, 10:39 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Where is the ATF refill hole?
1. Pull out the dipstick.
2. Using a long neck funnel, add fluid at the dipstick hole.
Add only enough fluid to bring the fluid level up into the middle of the cross-hatched area on the dipstick.
3. After adding fluid, recheck fluid level.
4. Push the dipstick back in all the way.
DEXRON-III may be substituted if Saturn transaxle fluid is not available.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-01-2008, 10:47 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
While you're at it, remove and replace the filter. Might as well do it now since all the fluid is out. Then you're good to go until the next tranny service.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 01-01-2008, 11:14 PM   #4
MythicalForce
1999 SW1
Is the trans filter a dealer only part or can I get this at Napa or Checkers? How much fluid should I buy for a complete fluid change?
Old 01-01-2008, 11:46 PM   #5
Old95SL2
Old95SL2 is on a distinguished road
1997 SL1
I've used NAPA trans. filters without any issues, I am thinking 5qts fluid should do, seems like I usually get about 4 1/2 out. The NAPA brand fluid worked fine too. Filter is around $10, with fluid you can do the job for $20-25 total.
A filter wrench may come in handy for breaking the old filter loose.
Old95SL2 is offline   Reply With Quote
Old 01-01-2008, 11:49 PM   #6
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
In the past I bought Fram trans filters for it at AutoZone. They were never cheap from what I remember... ~$11.00
2006 Black VUE Red Line - Now running iOS 14.7 beta
Old 01-02-2008, 12:38 AM   #7
bobfather99
bobfather99 is on a distinguished road
2004 ION-2 Sedan
Dont forget that when you check trans fluid the fluid should be hot, engine running, car on a level surface.
Saturn recommends checking the fluid several times in rapid succession to get an accurate reading.
Napa filters are fine, and any brand ATF will work. Wolfman recommends Mobil 1 ATF(synthetic)
Just dont buy ATF+4 fluid (7176 fluid), which is for Chrysler vehicles...
bobfather99 is offline   Reply With Quote
Old 01-02-2008, 12:39 PM   #8
Luke
Luke's Avatar
And, as an additional suggestion, when pouring in the ATF fluid, do it very slowly, for should you pour quickly, the small size of the funnel, will result in a 'burp', with the fluid quickly backing up -- and splashing out.....
Luke is offline   Reply With Quote
Old 01-03-2008, 07:24 PM   #9
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
YEp, just about to say that...pour it in VERy slow......
A Saturn Trany filter is $12....better to go with OEM on this one
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
xtremeranger is offline   Reply With Quote
Old 01-03-2008, 10:05 PM   #10
nivlem7
nivlem7 is on a distinguished road
Some say you should remove the car's magnet with an aftermarket filter, if the magnet's still in there. I believe it helps flow through the filter, and the magnet is only necessary until the first tranny service. The magnet will be right where the filter threads on. If it's there, it's most likely covered in a ton of metal filings.
nivlem7 is offline   Reply With Quote
Spent entire day looking for Mobil1 ATF or AMSOil ATF and still nothing SuperCujo S-Series General 9 07-02-2009 03:35 PM
2001 L200 ATF Drain & Refill Questions headmotty L-Series Tech 5 06-19-2009 11:10 AM
ATF Fluid Level / Dipstick & What Are The Symptoms of Overfilled ATF CND_SC1 S-Series Tech 7 01-20-2008 09:14 AM
Anyone know how much an ATF flush costs? (Honda ATF?) m4gician Vue General 9 10-25-2007 10:48 AM
Which is Better? Castrol/Allison TranSynd ATF or Mobil 1 ATF? tgparker S-Series Tech 2 12-20-2005 02:26 PM
