Old 09-17-2021, 03:45 PM   #1
goBoating
goBoating will become famous soon enoughgoBoating will become famous soon enough
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Default Source for 2004 Vue 3.5l oil sender switch
Getting the low oil pressure idiot light. Touch accelerator to increase RPMs slightly and the light goes out.
Took car to shop. They couldn't find an oil pressure sender switch. It has one wire. All the switches they found had 2 or 3 (for Hondas). They cleaned the old one and put it back in. That seems to have helped. But, I don't expect it to work for long.
Any idea where I can find one to fit a 2004 Vue 3.5l?
Or, what Honda part number might match?
Or, what Honda part would work if I also replace the electrical connector?
Thanks
Don't Tread on Me
A strict constructionist fiscal conservative free market freak I am.
"The problem with socialism is that you eventually run out of other people's money." - M. Thatcher
goBoating is offline   Reply With Quote
Old 09-17-2021, 07:39 PM   #2
Default Re: Source for 2004 Vue 3.5l oil sender switch
Try rockauto as they show two and one wire oil pressure sending units.
Old 09-20-2021, 11:58 AM   #3
goBoating
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Appears the 2004 Honda Pilot uses a one wire setup. Going to try that one.
Anyone know where the oil pressure switch is on the Vue V6/Honda motor?
I see things showing some Honda 3.5 motors with in different places depending on car model and year.
Maybe beside/behind the starter?
Take passenger wheel off.
Remove inner wheel well.
Don't Tread on Me
Old 09-22-2021, 11:49 AM   #4
goBoating
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Just answering my own question. Spent the $20 for the PDF manual at http://emanualonline.com and got a manual. Figured if I'm going to keep a nearly 20 yr old Saturn going, will likely need it again.
Re: the location of the oil pressure switch on the motor.
Looking into the passenger side front wheel well, the switch is on the lower part of the motor, slightly above the oil filter, and on the back face (facing the firewall) of the motor. It is forward of and above the CV joint boot.
Don't Tread on Me
Oil pressure sensor/sender switch -what part number? Nigey Aura General 3 09-02-2020 08:28 PM
2004 won't start after new switch murray11 Ion General 11 09-14-2013 06:15 PM
Source for 00-02 Power Window Switch? jamesvolson S-Series General 4 09-15-2011 09:01 PM
Vue 2004 headlight switch TomWaddington Vue General 15 01-24-2011 01:31 PM
2004 VUE 2.2 A/C Blower Switch? uhlemd Vue Tech 7 07-15-2010 02:02 PM
