Old 10-01-2006, 12:40 AM   #1
asdf
asdf is on a distinguished road
Default DOHC Valve Spring Compressor
I've searched this forum in and out and I don't think my answer lies within.
Has anyone come across an aftermarket valve spring compressor that works on the DOHC?
I would like to invest in one, I don't want to risk damaging anything like last time..
asdf is offline   Reply With Quote
Old 10-01-2006, 06:00 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: DOHC Valve Spring Compressor
There's a guy on turbosaturns who has one made up from a largish c-clamp with a certain size socket welded on the end. Unfortunately that site is down or I'd search for a pic.
Old 10-01-2006, 07:27 PM   #3
stanleyr
stanleyr is on a distinguished road
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Invest in one, eh? I couldn't find one in the aftermarket world that I knew would absolutely work, so I didn't take the chance. If you are equipped with some basic wood and metal working equipment, you may be able to make one that works well. It uses the same cantilever type construction that is depicted in the FSM.
IIRC, I made mine from solid oak lumber, steel rod, aluminum tubing, and nylon inserts. If you want me to send you some photos, I'd be willing to. Just PM me and I'll get the pieces together for a photo shoot.
stanleyr is offline   Reply With Quote
Old 10-02-2006, 01:01 AM   #4
Frank3
Frank3 is on a distinguished road
Are you lookng of one that works with the head still installed on the engine or one that works with the head on a bench?
Frank3 is offline   Reply With Quote
Old 10-02-2006, 11:57 AM   #5
Low Saturn
Low Saturn's Avatar
2007 AURA XR
We use one of these. Can be found pretty cheap on ebay.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-03-2006, 02:20 PM   #6
project92SC2
project92SC2 is on a distinguished road
1992 SC2
1991 SL2
go to partsamerica.com (schuck's, advance auto parts, kragen, and checker stores) and look up part# T75502. It's an OHC valve spring compressor.
I haven't tried it myself yet, I will, then I'll post whether it's worth it or not.
project92SC2 is offline   Reply With Quote
Old 10-04-2006, 01:38 PM   #7
charcoal
charcoal is on a distinguished road
1993 SC2
I successfully used a vice-grip brand bar clamp and a 3/8" drive 5/8" deep socket that I ground off 1/3 of two sides to expose the center. I then used a pair of small forceps to delicately extract/insert the keepers thru the openings in the socket sides.
Using this jury-rig requires an extended level of dexterity but I did all 16 without a single scratch to the lifter bores -or a trip to the little big tool store.
PM me if you want an image of the socket/clamp combo, but the hogged out socket looks very similar to the image seen in Low Saturn's response.
MAD works!
charcoal is offline   Reply With Quote
Old 10-04-2006, 02:23 PM   #8
asdf
My concern would be bending the valves. The compressor has to sit on the valve face flat and evenly. It says in the FSM that the wrong compressor can damage the valves.
Valve spring compressor? WILLH68 S-Series Tech 3 05-09-2008 11:52 PM
Valve spring compressor adapter for DOHC heads srponies S-Series Tech 4 04-09-2007 01:12 PM
DOHC valve spring compressor charcoal S-Series Mods 1 08-27-2006 11:52 PM
DOHC Valve Spring Compressor sps SOHC S-Series Tech 4 06-09-2005 09:16 AM
Valve Spring Compressor kev99sl Miscellaneous Tech 6 03-15-2001 11:03 PM
