Old 05-30-2021, 10:15 PM   #1
Saturneveragain
Saturneveragain is on a distinguished road
Default 2008 Saturn Vue Ignition key stuck. Permanent fix, ideas for
Hey all,
I spent a solid 8 hours today “fixing” my fiancé’s terrible “key stuck” problem that officially doesn’t exist. Thanks to a few posts on this forum and some YouTube’s I managed to get the automatic shifter housing removed and the shifter pulled out so I could “fix” the metal wire switch to activate when shifting. Due to the terrible engineering of this piece that was no way I could bend the metal clip, or alter anything to make it work when when normally installed.
So, I took it out and now I have to depress the button by hand to get my key out of the ignition. Anyone with any electrical know how suggest a way to make this easier? Could I cut the wires and wire to a toggle switch and then just flip it to remove the key? Can I just tape something down and keep it permanently pressed?
Any suggestions are much appreciated.
The pictures show the switch and metal lever activator, the bump that needs to be pressed is circled in red.
Thanks
File Type: jpg C959DFE5-0D89-46B4-8563-5B33AB17D35B.jpg (153.9 KB, 1 views)
File Type: jpg 7433C739-D9B8-48DA-96FE-EFE71CF4AA54.jpg (150.9 KB, 1 views)
Saturneveragain is offline   Reply With Quote
Tags
automatic, ignition, stuck ignition key
2008 Saturn Vue key stuck in ignition Azimzim 2008 Vue 11 03-03-2021 08:09 PM
98 Saturn SL2 key stuck in ignition mwilson27 S-Series Tech 2 11-05-2019 11:02 PM
Key stuck in ignition 2008 Saturn Outlook oilersgirl Outlook General 3 02-19-2013 11:32 PM
Key stuck in ignition 2008 Saturn Outlook XR oilersgirl S-Series General 3 08-02-2012 11:17 AM
Ignition Cylinder permanent fix? AC962 Ion General 2 05-08-2011 03:39 PM
