Old 04-10-2021, 02:16 AM   #1
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 (L81/3.0L V6) - Front Camshaft Cover Gasket [Removal/Replacement]
Hey there everyone!
I have successfully replaced the Front Camshaft Cover Gasket using the same way that I did the Rear Camshaft Cover Gasket by using a hefty amount of Red High Temp RTV. Since the Rear Camshaft Cover Gasket Replacement; I have been leaning toward using RTV as an outside sealant for extra re-enforcement. It's oxygen sensor safe and I don't mind seeing RTV around my L81.
Torque Specs:
17 inch pounds (Front Camshaft Cover Bolts)
Tools Needed:
  • Torque Wrench (Ratchet)
  • New Camshaft Cover Gasket
  • High Temp O2 Safe RTV
  • Q-tips (I used them for smearing RTV and keeping certain areas clean -- this time I barely used a Q-Tip. I ran the RTV Tube against the rail and then immediately taped. It didn't seem to cause too many bulging spots that required pressure other than the tape and the best "tape over" as possible).
  • Gasket Scraper
  • Anti-Seize Lubricant (For Bolts)
  • Masking Tape (If you also wish to use it to hold pressure down on the rubber gasket to wet RTV)
  • Gunk Spray (To clean the oil off the Rear Camshaft Cover)
  • Wire Brush (To clean the oil off the Rear Camshaft Cover)
  • Rags (To clean the oil off the Rear Camshaft Cover)
Attached Pictures are Gallery A:
Best Regards,
~ Brandon Kastning
~ TruthSword
WE THE PEOPLE ONLINE
http://wethepeopleonline.com
U.S. Const. Art. VI, Clause 2, 3 (September 17, 1787).
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 04-10-2021, 02:18 AM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 (L81/3.0L V6) - Front Camshaft Cover Gasket [Removal/Replacement
Gallery Part-B:
Old 04-10-2021, 02:20 AM   #3
BrandonKastning
Gallery Part-C:
Old 04-10-2021, 02:21 AM   #4
BrandonKastning
Gallery Part-D:
Old 04-10-2021, 02:23 AM   #5
BrandonKastning
This is a wrap for the night. I will let the RTV dry like last time and see if everything fits smoothy on the Front Camshaft after a cleaning.
Gallery Part-E:
Old 04-10-2021, 08:50 AM   #6
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
Default Re: 2001 Saturn L300 (L81/3.0L V6) - Front Camshaft Cover Gasket [Removal/Replacement
https://www.permatex.com/products/ga.../?locale=en_us
DIRECTIONS:
1) For best results, clean and dry all surfaces with a residue-free solvent such as Permatex® Brake & Parts Cleaner.
2) Cut nozzle to desired bead size. Gaskets are best formed using a 1/16” to 1/4” bead.
3) Apply a continuous, even bead of silicone to one surface, surrounding all bolt holes. Assemble parts immediately while silicone is still wet.
4) Finger tighten until material begins to squeeze out around flange.
5) Allow to dry for one hour then retighten 1/4 to 1/2 turn.
6) Silicone will skin over in one hour and fully cure in 24 hours under normal conditions. Allow more time for cold or very dry conditions.
7) Clean uncured silicone from hands, tools and clothing with Fast Orange® Hand Cleaner.
NOTE: Not recommended for use on head gaskets or parts in contact with gasoline.
These directions are straight from the Permatex! Brandon, you have invented a new mythology to use RTV. I hope you know your engine will be puking oil much worse than before! Good job!
Rj 2000 LS2 is offline   Reply With Quote
Old 04-10-2021, 04:08 PM   #7
BrandonKastning
Alright everyone; here is the wrap up on the Front Camshaft Cover Gasket Replacement + Installation.
I have re-assembled successfully with Torque specs to 71 inch pounds.
This concludes this thread on my end. Thank you everyone!
This is Gallery Part A:
Best Regards,
~ Brandon Kastning
~ TruthSword
Old 04-10-2021, 04:10 PM   #8
BrandonKastning
Gallery Part-B:
Old 04-10-2021, 04:11 PM   #9
BrandonKastning
Gallery Part-C:
Old 04-10-2021, 04:12 PM   #10
BrandonKastning
Gallery Part-D:
Old 04-10-2021, 04:14 PM   #11
BrandonKastning
Gallery Part-E:
Old 04-10-2021, 04:16 PM   #12
BrandonKastning
Gallery Part-F:
Old 04-10-2021, 04:17 PM   #13
BrandonKastning
Gallery Part-G:
Thanks again everyone!
Old 04-16-2021, 09:42 PM   #14
BrandonKastning
On my Rear Camshaft Cover Gasket [Removal/Replacement] thread I made a mistake of not seeing a missing o-ring gasket which all were hardened. RJ 2000 SL2 was indeed correct that they need to be removed and replaced with the soft ones.
I finished the rear and moved to the front to perform the same replacement and the following galleries will show this being done.
This should just about finish this thread out!
Gallery A.1:
Best Regards,
~ Brandon Kastning
Old 04-16-2021, 09:43 PM   #15
BrandonKastning
Gallery A.2:
Old 04-16-2021, 09:44 PM   #16
BrandonKastning
Gallery A.3:
Old 04-16-2021, 09:45 PM   #17
BrandonKastning
Gallery A.4:
Old 04-16-2021, 09:47 PM   #18
BrandonKastning
Gallery B.1:
Old 04-16-2021, 09:48 PM   #19
BrandonKastning
Gallery B.2:
I am doing an overnight dry and then a ratchet & torque down later!
Old 04-17-2021, 02:14 PM   #20
BrandonKastning
Hey everyone!
I can barely type (joints/muscles are all locked up all over my hands and body).
Finished this job.
Gallery Part.A
Thank you everyone!
Best Regards,
~ Brandon Kastning
~ TruthSword
U.S. Const. Art. VI, Clause 2, 3 (1787).
Tags
front camshaft gasket, l300, l81
2001 Saturn L300 (L81/3.0L V6) - Lower Intake Manifold Gasket/Thermostat Replacement BrandonKastning L-Series Tech 51 04-19-2021 09:31 AM
2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover Gasket [Removal/Replacement] BrandonKastning L-Series Tech 48 04-17-2021 02:12 PM
2001 Saturn L300 (L81/3.0L V6) - Front Camshaft Cover + Front Guard/Mount [Removal] BrandonKastning L-Series Tech 17 04-10-2021 09:20 AM
2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover + Rear Guard/Mount [Removal] BrandonKastning L-Series Tech 15 04-07-2021 01:04 AM
2001 Saturn L300 (L81/3.0L V6) - Pre-Question for Head Gasket DIY Replacement BrandonKastning L-Series Tech 49 03-09-2021 01:11 PM
