Old 04-07-2021, 12:47 AM   #1
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover + Rear Guard/Mount [Removal]
Hey there everyone!
I have successfully removed the Rear Camshaft Cover Guard/Mount & have full access to replace all Gaskets contained within.
Tools Needed:
  • E8 (fuel rail)
  • E10 (guard mount - rear camshaft & passenger side rear camshaft fuel hose mount)
  • Gasket Removal Tool (or pry bar) to pop the cover lid and clean it up.
  • T30 Torx Socket (PVC fuel mount bolt)
  • Zip-Ties (optional) (I used them for pulling back the black metal sheet that has cabling connected to it to allow my ratchet to reach E10 bolts on the guard mount). I had to kneel on the camshafts to get to all the bolts. I found this to be very difficult.
  • 3M Automotive Masking Tape (optiona) (Wanted to be extra careful that I didn't drop anything or contaminate the ports.)
Note: On the passenger side rear, rear camshaft; there was a large liquid oil deposit that appears to be Rj 2000 LS2's assertion that this was the source of my engine oil leak in previous threads; It looks as if he is correct.
Next up is changing out the O-Ring Gaskets & Rubber Gasket [oil lubricated for fitting; and RTV for molding/hardening] is my plan and re-assembling the Rear Camshaft Guard/Mount and other assemblies.
Attached Pictures are Gallery A:
Best Regards,
~ Brandon Kastning
~ TruthSword
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 04-07-2021, 12:48 AM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover + Rear Guard/Mount [Removal]
Gallery Part-B:
Old 04-07-2021, 12:49 AM   #3
BrandonKastning
Gallery Part-C:
Old 04-07-2021, 12:50 AM   #4
BrandonKastning
Gallery Part-D:
Old 04-07-2021, 12:52 AM   #5
BrandonKastning
Gallery Part-E:
Old 04-07-2021, 12:53 AM   #6
BrandonKastning
Gallery Part-F:
Old 04-07-2021, 12:54 AM   #7
BrandonKastning
Gallery Part-G:
Old 04-07-2021, 12:55 AM   #8
BrandonKastning
Gallery Part-H:
Old 04-07-2021, 12:56 AM   #9
BrandonKastning
Gallery Part-I:
Old 04-07-2021, 12:57 AM   #10
BrandonKastning
Gallery Part-J:
Old 04-07-2021, 12:58 AM   #11
BrandonKastning
Gallery Part-K:
Old 04-07-2021, 01:00 AM   #12
BrandonKastning
Gallery Part-L:
Old 04-07-2021, 01:01 AM   #13
BrandonKastning
Gallery Part-M:
Old 04-07-2021, 01:02 AM   #14
BrandonKastning
Gallery Part-N:
Old 04-07-2021, 01:03 AM   #15
BrandonKastning
Gallery Part-O:
Old 04-07-2021, 01:04 AM   #16
BrandonKastning
Gallery Part-P:
Tags
l81, rear camshaft cover, rear camshaft gaskets
2001 Saturn L300 - v6 3.0 Liter - Timing Belt Kit + Camshaft + Crankshaft Seals BrandonKastning L-Series Tech 659 07-26-2021 10:11 PM
2001 Saturn L300 - v6 3.0 Liter - Rear Brake Pad Swap (Special Tool Needed) ? BrandonKastning L-Series Tech 68 05-31-2020 09:06 PM
2001 Saturn L300 - Battery Harnass Removal Problem + Left headlight Removal Issue BrandonKastning L-Series Tech 14 02-26-2020 02:06 PM
2001 Saturn L300 Rear Brake Calipers - Phenolic or Metal? TravelerL300 L-Series Tech 9 08-31-2013 12:31 PM
Rear bumper cover removal? froggy81500 Ion Tech 5 09-12-2007 11:45 AM
