Old 03-31-2021, 09:21 PM   #1
seansaturn
seansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of light
seansaturn's Avatar
Default Vibration while accelerating (not inner cv)
I am getting a vibration/shudder under load. It's usually always from a stop or from very slow speed.
What I've noticed, it vibrates when:
Driving straight from a stop (under hard acceleration)
Driving from a stop around a RIGHT corner
The vibration is under the drivers floor area
It feels like the wheel is skipping or something.
Doesn't vibrate when:
Driving from a stop around a LEFT corner
Not under load, normal driving
- I replaced the CV axle on the front drivers side, problem didn't go away.
- I replaced the motor mounts (airbox, front and rear mounts)
- I rotated wheels and checked lug nuts
- I replaced the CV axle on the front drivers side again, thinking I got a bad one, problem didnt go away
- Drive shaft not installed currently
I was thinking maybe a transmission bearing where the CV axle enters the transmission, or, the 4th mount that connects the transmission to the sub-frame on the far left drivers side.
The mount honestly looked ok visually, but i havent taken it out or anything.
I strapped a GO Pro camera to the inner tie rod, and it looks like the transmission shakes. I'm not sure how much it should shake, I can upload the video if needed.
I wondered what steps I can do to confirm an exact diagnosis on this.
Thanks
Saturn Vue 2007 AWD 3.5L V6 - Honda J35S1/GM L66 Engine
GinkoSolutions.com
seansaturn is offline   Reply With Quote
Old 04-20-2021, 10:30 AM   #2
Cavell
Default Re: Vibration while accelerating (not inner cv)
Where did you buy motor/trans mounts? Online? Dealer?
Old 04-25-2021, 08:30 AM   #3
seansaturn
seansaturn's Avatar
I pulled them from a salvage yard, 30K mile car, rear ender. OEM
When I changed them, it didnt change anything at all. Vibration was exactly the same. I thought if it were the mounts, then it would change behaviour in some way.
It also wouldn't explain why the vibration isn't apparent when turning left from a stop under load, but right, very much so.
So I have ruled the mounts out at this point, at least the 3 I mentioned in the OP. I checked the 4th mount bracket on the far drivers side, but it looks ok visually and the bolts are not loose in any way
GinkoSolutions.com
Tags
saturn vue, vibration, vibration @ acceleration
Vibration while accelerating seansaturn Vue General 7 09-03-2020 05:51 PM
vibration while accelerating at low speed dude33333 S-Series Tech 6 09-20-2016 07:27 PM
Vibration when accelerating djwirthless L-Series Tech 4 03-13-2008 11:31 AM
Vibration when accelerating Bobhasfun Vue Tech 5 11-15-2005 07:39 PM
AWD Vibration while accelerating Druce Vue General 8 09-09-2004 08:27 AM
