Old 09-18-2020, 01:11 PM   #1
Jake371
Jake371 is on a distinguished road
Default How to install aftermarket drive shaft on 2004 Vue 3.5 V6 AWD
So we had our Vue in for warranty work several years ago at Saturn dealer to diagnose and fix a random vibration at light throttle. They never were able to fix it (if anyone has ideas as to what it is, please LMK) after multiple times in for service.
The final time we took it in, they had it for days and we finally told them we needed to pick it up...so we did.
Here's where the story gets "fun." We just learned to live with the issue we took it in for and went on our way. Saturn finally closed up. A couple years later we had the Vue up on a rack and noticed something strange...it took minute and then it sunk in. The Saturn mechanics had removed our AWD drive shaft (apparently as part of the diagnosis, or as a potential solution) AND NEVER REINSTALLED IT!
We've been driving w/o a drive shaft for several years. WTF - The vehicle is in really good shape otherwise, so on to a solution where I need your help.
QUESTIONS: I purchased an assembled and balanced (ready for install) aftermarket driveshaft from GLH through Amazon and it'll be here in a week or so. There are no bolts or other pieces included, and they were not put back in their place on the car either. ó What do I need to install this other than a torque wrench (what is the torque for each connection too please)?
I'm assuming that I just need 6 bolts for front connection, 2 for middle and 4 for rear. These I can get from Rock Auto or AutoZone (out of stock currently though). However I've seen photos where there's a span washer between each two bolts on the front...please explain?
Are there any other considerations I should be aware of?
Will I need to take it to shop to install, or just to confirm balance after install, or no worries?
Your feedback with photos/video is greatly appreciated. Thx, Jake
File Type: jpg Screen Shot 2020-09-18 at 1.09.57 PM.jpg (48.1 KB, 13 views)
Jake371 is offline   Reply With Quote
Old 09-18-2020, 05:11 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: How to install aftermarket drive shaft on 2004 Vue 3.5 V6 AWD
....The only company i would buy from ,when it comes to aftermarket driveshafts , is shaftmasters. It is a night and day diff. compared to the stock piece or anything that looks like it. It uses spicer ujoints , it is thicker, it also uses a slip joint instead of the cv end . Mine came with the bolts, and if there is any issues ,you can send it back and have them fix it or rebalance it , I highly recommend them if you plan on keeping your vue for a while, also with your D.S, you should be able to get grade 8 bolts from any driveshaft rebuilding facility, just my.02,hope that helps,DC.
Old 09-19-2020, 04:06 PM   #3
Cavell
Grab a used one at junkyard. I found one with a new carrrier bearing. $35 I think?
Old 09-19-2020, 08:41 PM   #4
atikovi
So why all of a sudden do you now think you need one? How many miles? Chances are the rear module is toast and it won't do anything anyway.
Old 09-21-2020, 07:29 PM   #5
Jake371
Because I live in the midwest and would like to utilize the AWD I purchased the vehicle for. Why would the rear differential be a problem? Changing the fluid should be in order, yes.
Old 09-21-2020, 07:47 PM   #6
atikovi
They tend to be a weak point on these models.
Old 11-08-2020, 09:55 PM   #7
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Sometimes... if itís still the original 2004 RDM that is quick to engage. I have a 2006 RL a AWD with 300,000 kms on the odometer and the rear RDM is still working fine (in its normal crappy sort of way - with the delayed engagement). And it gets used a lot in the winter so the later updated/neutered ones can/do last.
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
Old 03-27-2021, 04:44 PM   #8
Jake371
Wrench Re: How to install aftermarket drive shaft on 2004 Vue 3.5 V6 AWD
Anyone know where I can find bolts for the center mount on this? I can't find them anywhere. Thx
Old 03-31-2021, 05:40 PM   #9
Cavell
I measured mine. .312 dia. Not sure if itís metric or inch. Could be 5/16Ē or M8.
File Type: jpg 8518F893-49D8-4EF9-8E85-9E45DF7148B6.jpg (144.0 KB, 7 views)
Old 03-31-2021, 05:44 PM   #10
Cavell
5/16 or M8
File Type: jpeg 93F79838-E4EB-4A9C-9A85-B123F8812760.jpeg (45.1 KB, 12 views)
Old 03-31-2021, 07:07 PM   #11
Jake371
Thank you
Tags
awd, drive shaft, installation, vue
mint drive shaft? Cavell Vue General 0 10-02-2018 04:18 PM
Drive shaft 04SVB Vue Tech 0 06-08-2018 04:04 PM
Install of aftermarket deck into 2004 QC raverMJK Ion Tech 9 07-05-2007 09:32 AM
2004 Saturn Ion Aftermarket Radio Install siren001 Ion General 8 07-29-2006 10:27 PM
2004 Ion Aftermarket Stereo Install freyguy8 Ion General 27 09-17-2005 11:31 AM
