Old 08-19-2020, 03:25 PM   #1
Gsk1500
Gsk1500 is on a distinguished road
Default 2000 sl2 starting on its own
I replaced the ignition cylinder in my 2000 SL2. In the process of trying to remove the old one the car started by itself when the old cylinder was removed. In hopes of putting the new one in it would fix the problem, it did not. What can I do to solve this issue?
Gsk1500 is offline   Reply With Quote
Old 08-19-2020, 04:35 PM   #2
toggenburg
toggenburg's Avatar
Default Re: 2000 sl2 starting on its own
Hello, welcome to the Forums!
The only thing common to both starter and ignition is the ignition switch.
I'd say, the wires for the battery terminal on the ignition switch is swapped (or wire jacket skinned) making contact with the starting terminal on the ignition switch and is causing your starter to engage.
The car is an automatic I presume?
Old 08-19-2020, 04:36 PM   #3
There are two parts to the ignition system. The key fits into the mechanical lock cylinder to unlock the steering wheel. The lock cylinder is keyed to fit into the ignition switch that controls the electrical system that powers up EFI and provides 12v to the starting circuit to power the starter.
Which one was replaced? Lock cylinder or ignition switch?
Old 08-23-2020, 03:45 PM   #4
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
I would guess that the double "D" actuator post that the ignition lock cylinder slides onto in it's bore is slightly twisted relative to where it's supposed to be.
You can try loosening the 3 screws that hold the ignition switch to the opposite end of that actuator post, and rotating the switch to bring it back to it's proper position.
There also might be an issue where the steering wheel is torque-locked against the ignition cylinder's security lock causing a bind in the column, thus not allowing the ignition lock actuator post to relax back into position. Try turning the wheel away from where it's jammed and see if things relax.
Preston
PrestonIII is offline   Reply With Quote
Tags
2000 sl2 saturn
2000 SL1 not starting Mike 2000 S-Series Tech 30 02-24-2017 01:39 PM
2000 sl2 starting issues. Combat2000 S-Series General 1 03-27-2013 01:49 AM
2000 SC1 not starting Payaso S-Series Tech 15 12-27-2012 04:45 PM
2000 SL not starting zzzbenbert L-Series Tech 1 10-10-2011 08:02 PM
2000 LS2 Starting Problem chrisl68 L-Series Tech 2 04-26-2007 06:06 PM
