Old 07-03-2020, 05:19 PM   #1
seansaturn
seansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of light
seansaturn's Avatar
Default Wheel Alignment
Hi,
I have a couple of questions about wheel alignment on my Vue (Saturn Vue 2007 AWD)
I have replaced a CV joint, tie rods (inner and outer), lower ball joints and sway bar links (all on front end). It's pulling to right and kinda mini-bouncing on sharp corners. I assume its all down to the alignment, so I didnt worry about it. It's next on the agenda!
I have been trawling through the internet, and I think I have found the best deal on alignment in my area which is at Pepboys: https://www.pepboys.com/auto-service...sion/alignment
They offer a lifetime alignment for $150 (Lifetime of vehicle)
I was wondering:
1. Is there any reason the 2007 Vue cannot be aligned at the rear? I didn't want them to up sell me a "Wedge Adjustments/Shim Kit" if I didn't need one. I wanted to go in knowing my options
2. Is there anything to watch out for? Do all places adjust toe, camber and caster? I heard some only check for toe, so it had me concerned.
Thank you
Saturn Vue 2007 AWD 3.5L V6 - Honda J35S1/GM L66 Engine
GinkoSolutions.com
seansaturn is offline   Reply With Quote
Old 07-06-2020, 02:28 PM   #2
seansaturn
seansaturn's Avatar
Default Re: Wheel Alignment
Any input?
GinkoSolutions.com
Old 07-06-2020, 04:35 PM   #3
waiter21
2003 VUE 2.2L
Before you take it in, look under the rear suspension and inspect for broken camber / caster bolts, common problem. Also look at the control arms for rusted out fittings, common.
I had a broken bolt on mine. I replaced all the rear bolts and new cam nuts.
On the front I'm currently repairing the front engine cradle attach points.
Old 07-07-2020, 11:03 PM   #4
seansaturn
seansaturn's Avatar
Thank you for the input! Appreciated!
I took a look at the bolts, they actually look really good. I think there was a recall on these right? Looks like they were done before I bought the car.
It looks a little rusty around the control arms, but it's not so bad! I had them off to replace the rear coil spring bushings and it wasnt ceased
Some extra things I thought about after making this post:
1. I checked the ride height (ground to wheel arch) was the same on both sides. This can affect alignment. (I.e. If a shock is bad or other suspension component)
2. I made sure all my tires were the same size (I was temporarily running one a little smaller for a couple of days)
3. I checked what IS stock adjustable on this car. It looks like the camber can be adjusted out of the factory and obviously the toe too. It looks like the caster is not adjustable, at least by default.
4. Two of my tires had slightly more tread, so i put those on the rear.
Best offer I found:
I looked into the PepBoys offer more, they offer 3 alignments per year for the lifetime of the vehicle. They will adjust castor, camber and toe providing they are adjustable. $189 in store, but $150 via the website. They do a free tire rotation too.
I have attached the default wheel alignment specs to this thread. I wanted it to have some value for others too!
GinkoSolutions.com
Tags
alignment, saturn vue 2007
When you need a wheel alignment Mark121 S-Series General 2 01-11-2016 04:38 PM
Tie rods again & wheel/steering wheel alignment 92SC2 S-Series Tech 3 02-09-2009 01:33 PM
Wheel Alignment? spencerb Vue Tech 1 09-18-2006 12:24 PM
'92 SL2 wheel alignment EnglishSL2 S-Series General 6 03-04-2005 12:44 PM
Wheel alignment rogerk Miscellaneous Tech 2 05-30-2001 07:49 AM
