Old 05-29-2020, 05:05 PM   #1
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 - v6 3.0 Liter - Upper Intake + Replacements (Picture Tutorial)
Couple things to note on this gallery!
~ It worked great aside from the internal computer 'marrying' the equipment ID. Passlock is angry at the moment. Thanks to fdryer; I will be picking up a VXC NAXO OBDII to solve this!
~ I used O2 Oxygen Sensor Safe Gasket Seal (High Temp)
~ I realized when re-assembling the EGR that after struggling with it not connecting to the Upper Intake again; that (at the Junkyard [Pick-N-Pull]) I never pulled the connector on the Upper Intake. I pulled it off the old one; then re-attached and it connected perfectly again.
Wanted to include that so nobody got confused if anyone wants to check out this galleries!
I took a total of 43 (5 Pictures per one) on the day I did this (earlier this month).
Here goes nothing!
Gallery #1 / 43: Prep and MAF
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 05-29-2020, 05:07 PM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 - v6 3.0 Liter - Upper Intake + Replacements (Picture Tutorial)
Gallery #2 / 43: Disabling The Fuel Pump -- Disconnect Fuel Line
Old 05-29-2020, 05:08 PM   #3
BrandonKastning
Gallery #3 / 43: Air Filter
Old 05-29-2020, 05:11 PM   #4
BrandonKastning
Gallery #4 / 43: ECU Disconnect and Front Intake
Old 05-29-2020, 05:13 PM   #5
BrandonKastning
Gallery #5 / 43: Front Intake -- Prep Rear Intake
Old 05-29-2020, 05:14 PM   #6
BrandonKastning
Gallery #6 / 43: Labeling and Prep
Old 05-29-2020, 05:16 PM   #7
BrandonKastning
Gallery #7 / 43: EGR
Old 05-29-2020, 05:17 PM   #8
BrandonKastning
Gallery #8 / 43: Disconnects
Old 05-29-2020, 05:21 PM   #9
BrandonKastning
Gallery #9 / 43: Throttle Body 0
Old 05-29-2020, 05:22 PM   #10
BrandonKastning
Gallery #10 / 43: Throttle Body 1
Old 05-29-2020, 05:24 PM   #11
BrandonKastning
Gallery #11 / 43: Throttle Body 2
Old 05-29-2020, 05:26 PM   #12
BrandonKastning
Gallery #12 / 43: Throttle Body 3
Old 05-29-2020, 05:28 PM   #13
BrandonKastning
Gallery #13 / 43: PCV_Clogged_Hose_Removal
Old 05-29-2020, 05:30 PM   #14
BrandonKastning
Gallery #14 / 43: PCV_Clogged_Hose_Removal_2
Old 05-29-2020, 05:34 PM   #15
BrandonKastning
Gallery #15 / 43: Crankcase Housing 1
Last edited by BrandonKastning; 05-29-2020 at 05:37 PM. Reason: [Upload Errors _ Saying Duplicate Pics]
Old 05-29-2020, 05:38 PM   #16
BrandonKastning
Gallery #16 / 43: Crankcase Housing 2
Old 05-29-2020, 05:40 PM   #17
BrandonKastning
Gallery #17 / 43: Crankcase Housing 3
Old 05-29-2020, 05:43 PM   #18
BrandonKastning
Gallery #18 / 43: Throttle Body Fluids and ECU Area
Old 05-29-2020, 05:44 PM   #19
BrandonKastning
Gallery #19 / 43: Crankcase Housing Replaced with o2 Sensor Safe Gasket Sealing 1
Old 05-29-2020, 05:46 PM   #20
BrandonKastning
Gallery #20 / 43: Crankcase Housing Replaced with o2 Sensor Safe Gasket Sealing 2
Tags
2001 l300, l300 crankcase, l300 pcv housing, l300 upper intake
2001 Saturn L300 - v6 3.0 Liter - Broken Mounting Bolt BrandonKastning L-Series Tech 33 06-30-2020 10:03 AM
2001 Saturn L300 - v6 3.0 Liter - Seafoam in crankcase housing? BrandonKastning L-Series Tech 20 05-05-2020 08:37 PM
2001 Saturn L300 - v6 3.0 Liter - Testing Engine Vacuum Pressure BrandonKastning L-Series Tech 10 05-01-2020 10:24 PM
2001 Saturn L300 - v6 3.0 Liter - Won't stay running after a breakdown and bad... BrandonKastning L-Series Tech 502 04-25-2020 01:10 PM
2001 Saturn L300 - v6 3.0 Liter - STINGER Isolator 200 AMP + Auxilliary Power BrandonKastning L-Series Tech 28 03-14-2020 06:32 PM
