Old 01-08-2019, 09:01 PM   #1
Scizie
Scizie is on a distinguished road
1996 SW1
Default SW1 No Start
Cranks and sparks, but will not start.
I parked her in a parking lot ran into the store came back and she wouldn't crank, tried to jump it (obviously did nothing). I got her towed home and i then put a new starter in it, now it will crank but it will not start. I put in new plugs and wires. If you give it some gas it will pop a bit here and there but it wont actually start up. Any ideas?
(yes there is gas in the tank and yes i can hear the pump priming)
Here is a video of what it is doing,
youtu.be/UFivkso0Cic
Scizie is offline   Reply With Quote
Old 01-08-2019, 09:19 PM   #2
billr
Default Re: SW1 No Start
Try a quick blast of starting-fluid. If no firing at all with that, then take compression readings.
Old 01-08-2019, 09:51 PM   #3
Waiex191
Waiex191's Avatar
That link does not work for me. What YouTube keywords should I search for? SW1 no start doesn't work for me unless this happened 4 years ago.
Edit: did you check all the relevant fuses?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 01-08-2019, 09:55 PM   #4
Scizie
1996 SW1
youtube.com/watch?v=UFivkso0Cic&feature=youtu.be
the site wont let me post links because i havent made enough posts, so you are gonna have to copy past it. sorry for the trouble, not sure why it would pull up an old video for you, it pulls it up fine for me but there is the full URL^
Old 01-08-2019, 10:03 PM   #5
Cheyne
Cheyne has a spectacular aura aboutCheyne has a spectacular aura about
2000 SL2
Have you replaced the ECTS? Try cranking it with the gas pedal pressed completely to the floor.
Old 01-08-2019, 10:26 PM   #6
Waiex191
Waiex191's Avatar
That battery seems very flat to me. Both my saturns crank over a lot quicker. Can you charge or jump it?
https://m.youtube.com/watch?feature=...&v=UFivkso0Cic
I am wondering if the voltage is getting so low while cranking that it won't spark.
Bryan Cotton
Old 01-08-2019, 10:44 PM   #7
Scizie
1996 SW1
i was jumping it in that video, and the battery definitely does hold a charge
Old 01-08-2019, 10:46 PM   #8
Scizie
1996 SW1
yes i have changed the coolant temp sensor (forgot to mention that) didnt make an difference
Old 01-08-2019, 11:05 PM   #9
If you have spark, what about fuel? Even when you hear the pump run doesn't mean fuel is injected. Fuel and pressure are pump operations but injectors are engine computer functions. Did you check for a blown injector fuse? Removed spark plugs after several starting attempts? Under normal conditions, turning the engine over without starting implies fuel was injected. Remove spark plugs and examine them for fuel, wet and smelling of fuel to verify injector operation.
Sometimes engines flood and drowns spark. Holding throttle wide open while starting tells the pcm to stop injector operation, clear out flooded cylinders and as plugs dry out, ignite the leaned air/fuel mixture for a sputtering startup. One or two starting attempts about 5-10 seconds with throttle wide open should result in starting up. This presumes spark and fuel are entering cylinders.
Old 01-12-2019, 04:05 PM   #10
Scizie
1996 SW1
went out this morning and cleared the "flooded cylinders" (still not positive if they we actually flooded or not), didnt seem the make any difference. i then came back out about 30 min after that and tried starting it repeatedly (like 5 or 6 times) with 60% throttle, the final time it started firing on all cylinders but as soon as i let off the gas it died, so i gave it one more shot now in a fit of rage cranked the key and shot her up to red line, there was a huge cloud of smoke and then she died again, at this point im thinking ive totally porked her and im gonna have to buy a new engine, i optimistically gave her one more try with just my foot on the brake and she fired right up! she idles perfectly normal, no codes or anything, no smoke, running like nothing ever happened. took her around the block a few times no problems at all, so then i ballsed up and took her on the freeway, she ran like normal and fires up everytime now. i am absolutely baffled! i guess getting angry works out in you favor sometimes XD. huge thank you to everyone who gave me suggestions! you all have been incredible kind and helpful!
Old 01-12-2019, 05:15 PM   #11
In case you come back for another round......
How long did you crank the engine to clear out a (suspected) flooded engine? If you cranked long enough with wide open throttle for 5-10 seconds at least two times without the engine firing up, there may be three things left preventing startup even though you got the car running again - worn spark plugs, worn fuel pump and clogged fuel filter (if it hasn't been replaced every 100k miles). Remove spark plugs for examination to check gaps and plug condition. A fuel pressure gauge, borrowed from AutoZone can display pressures at ignition on time and with engine idling. Expect between 40-55 psi with little bleed off after turning on ignition. Pressures should jump immediately without hesitation.
Old 01-12-2019, 06:14 PM   #12
Cheyne
2000 SL2
Still sounds like it was flooded.
Did you replace the ECTS during this no-start episode? Did you inspect the ECTS connector for corrosion and wiring for breaks/splices when you replaced it?
Where did the temp gauge sit when you were out driving it?
Old 01-12-2019, 06:20 PM   #13
Scizie
1996 SW1
yes i did replace the ects, i didnt see any visible breaks in the wiring. it was sitting a bit below the half mark on the temperature gauge
Tags
crank no start, fire, no start, starter, starting problem
Flickering/dimming lights, and Rough idle start/cutoff at start KNGRK9 S-Series Tech 8 07-21-2017 07:25 AM
03 Saturn doesn't start periodically, but eventually does start Caveman1953 L-Series Tech 5 11-25-2011 10:15 PM
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 11:27 PM
Cold start fine, warm start takes a couple of tries FredM S-Series Tech 5 09-05-2008 05:03 PM
2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) mymimi75 L-Series Tech 1 08-18-2006 11:50 AM
