Old 10-30-2018, 03:02 PM   #1
Keblar
Keblar is on a distinguished road
Default Air coming from EGR?
I keep seeing EGR issues pop up on the forum lately. I wonder if emissions on the S-Series are more problematic when it starts getting cold. Anyway...
I was already going to be going though the Richpin EGR clean out because I've been getting the P0410 code (stays clear, then tends to come back on sustained high RPM loads, i.e. downshift on steep grades at highway speed), but i noticed something as I was swapping out ignition coils (unrelated intermittent P0341 - variable/low resistance, cracked swollen coil on the 4 1 bank) and noticed a high concentration of dry carbon on the head and valve cover are near the EGR.
When I test started up to make sure the coil swap was successful I noticed more noise than usual and could feel heavy rapid puffs coming from the EGR area.
This doesn't appear to be common. At least I can't find it in any of the MANY EGR threads. Just a compromised EGR gasket? Is the EGR a red herring, and the air/carbon is coming from something else in that area?
Incidentally, there are no real noticeable engine problems. Quick start. Steady idle. No hesitation or lurching.
I'll know more when I dig into the cleaning later in the week, but thought I might try to get an idea of what to look out for.
Keblar is offline   Reply With Quote
Old 10-30-2018, 03:45 PM   #2
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default Re: Air coming from EGR?
takin egr off and run it with out it and crank out all that carbon soot out . also good to use some carbon cleaner to release any buildup in the intake.toothbrush for 99ct helps at a dollar store. Or old one will do. Also vacuum leaks can cause insuffient flow to the egr . Low vacuum. Clean the exhaust and intake ports of the egr to see it helps with your lights on your dash . Check make sure hose going to intake dont have cracks . Especially the egr solenoid hoses going to intake. You can take a vacuum or a air pump to about 15 psi check for leaks . Also check the egr itself this can cause issues if it gets clogged it wont close fully causes a vacuum issue that can create a code. The emission system needs good vacuum also needs a good circuit A stuck egr pintle will show higher voltage
EGR valve fault codes:
P0401 EGR System Flow Insufficient.
P0403 EGR Solenoid Circuit.
P0404 EGR System Performance.
P0405 EGR Pintle Position Circuit Low Voltage.
P1404 EGR Valve Stuck Open.
P1406 EGR Valve Pintle Position.
Packard is offline   Reply With Quote
Old 10-30-2018, 03:49 PM   #3
Packard
1995
takin egr off and run it with out it and crank out all that carbon soot out . also good to use some carborator cleaner to release any buildup in the intake.toothbrush for 99ct helps at a dollar store. Or old one will do. Also vacuum leaks can cause insuffient flow to the egr . Low vacuum. Clean the exhaust and intake ports of the egr to see it helps with your lights on your dash . Check make sure hose going to intake dont have cracks . Especially the egr solenoid hoses going to intake. You can take a vacuum or a air pump to about 15 psi check for leaks . Also check the egr itself this can cause issues if it gets clogged it wont close fully causes a vacuum issue that can create a code. The emission system needs good vacuum also needs a good circuit A stuck egr pintle will show higher voltage if its stays higher voltage its clogged up take some cleaner acetone carbon cleaner alchol and take a screw driver and move it up and down and spin it as u go up and down to remove all that buildup. This will clear the passages and make it move without resistance. This will improve fuel economy . If u have open one this will make car run rich longer. Overheating the exhaust .
Old 10-30-2018, 05:05 PM   #4
Are you aware that P0410 - Secondary Air Injection System Malfunction
Read more at: https://www.obd-codes.com/p0410
It might help to update your profile to reflect what you're driving.
Old 10-30-2018, 05:12 PM   #5
Keblar
Dammit! I'm usually so good about that too. I got too casual in haste.
2002 SL2 with just under 300k
Will add profile though.
And I mislabeled the video in the OP. SHOULD have said, not only will I be doing the cleaning procedure to check the EGR and gasket, but I'll be troubleshooting the P0410 code leading up to that.
THANKS!
Old 10-30-2018, 06:29 PM   #6
So, did you get a P0410 or P0401?
P0401 Insufficient EGR Flow
Read more at: https://www.obd-codes.com/p0401
Old 10-30-2018, 08:29 PM   #7
Keblar
P0410 only.
I don't know that the fault code actually has anything to do with the EGR. I would tend to think they're likely related though.
Whether it is or not, I primarily want to fix the code, but yes, I still want to figure out where the carbon and weird air jet in the EGR vicinity is coming from. If I'm troubleshooting the P0410, I'd probably eventually get to checking the EGR anyway.
2002 SL2 328k + Miles
Old 11-03-2018, 03:21 PM   #8
Keblar
Started troubleshooting the P0140 code yesterday and I discovered that a rigid plastic tube that goes from the "vacuum check valve" over the left side of the head cover back to the intake was partially separated. I must have leaned on it at some point while working down into the compartment. I severed it as cleanly as I could and patched with some glue lined shrink wrap. So far the code is staying away. I'll patch with a short piece of vacuum hose on the outside diameter if the shrink wrap doesn't last.
The EGR does have air coming from it though, from the location circled here:
http://www.saturnfans.com/photos/sho.../s-egr/cat/500
It's at a point in between the valve and the base, from under the thin metal piece, not from the lower gasket. I don't think this was contributing to the P0410 code though, and that this is a different issue.
Is this an indication that the EGR is failing, even without a code, or is it some cold start function I'm unaware of?
Also, the EGR puffs are NOT the source of the extra engine noise. That's coming from someplace behind the valve cover, around the intake area. I'll need to get a stethoscope to isolate the sound. That's for another time anyway - one thing at a time.
Old 11-03-2018, 05:40 PM   #9
If I'm not mistaken, the red circled area looks like sheet metal sandwiched between the lower base and upper egr valve body. Intake manifold vacuum pulls exhaust gases from the exhaust system when the egr valve opens. Two ports underneath the egr valve. Since vacuum exists only when the engine runs, exhaust gases are ported to the egr valve, leaking out the egr valve assembly. At idle or wide open throttle the egr valve is closed. It's open in increments depending on engine rpm, load, coolant temperatures and other factors. When its open, manifold engine vacuum sucks in exhaust gases to lower combustion temps. If you're feeling what seems to be air pressure, it's not air but exhaust leaking out that area. You may have a faulty egr valve. Maybe sealing the gaps might work with high temperature exhaust cement. It's basically something resembling fine sand and glue to seal around exhaust pipes and small leaks where welding isn't an option. Replacing it with s used one would work too as long as the used one is in working condition.
Old 11-04-2018, 01:38 AM   #10
Keblar
You're right. I should have been more specific. It's definitely exhaust, because it gets scorching hot right quick after start up.
Tags
carbon, egr, egr leak, p0410
ABS coming on when coming to a stop on dry roads tbasse01 Vue Tech 16 03-08-2011 08:11 PM
Where is this oil coming from???? loonybin S-Series Tech 5 02-25-2006 01:19 PM
it's coming soon... 4everis2morrow Ion General 6 06-28-2003 11:39 PM
CAI's Coming soon Dj_Xao L-Series General 27 03-14-2003 03:04 PM
VUE Coming Soon? ricksLS1 Vue General 0 12-12-2001 04:48 PM
