Old 06-23-2017, 03:07 PM   #1
MDB
MDB is on a distinguished road
Dizzy Intake Manifold Issue?
Hello Everyone. Just a little background info. 2002 Saturn Vue AWD 3.0 V6. I am having a rough idle and a power issue. The Vue sounds like it is running a 4-barrel carb, when anything is given over easy throttle pressure. Kind of throaty sounding, if that makes any sense. Almost like it is getting way to much air into the intake. This happened after taking the top off of the intake manifold to take a look, while I was changing the thermostat, spark plugs, and ignition coils. I thing the intake flappers might be just staying open all of the time. Everything worked fine, until i performed maintenance on the vehicle. I noticed there is a vacuum line that splits and goes to each one of the flapper actuators. Is there suppose to be vacuum to these lines when the car is running? There wasn't any vacuum when I removed each one of the lines. Is there a way to check and see if the actuators are working? The vehicle has absolutely no power now. Any info that you can give me would be greatly appreciated. Thanks
MDB is offline   Reply With Quote
Old 06-23-2017, 08:36 PM   #2
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
Default Re: Intake Manifold Issue?
http://www.saturnfans.com/forums/sho...d.php?t=199461
I would look into your TPS (Throttle Position Sensor)
http://auto-repair.yoexpert.com/trou...-has-3250.html
Not familiar with your year...some wizards here, may offer some better info.
'Silven'
K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues
mellissam is offline   Reply With Quote
Old 06-24-2017, 04:27 PM   #3
MDB
Thank You for the response. I am thinking that it is probably something I did when I had the lid off of the intake. It must be something to do with that. The car ran fine, until the repair and maintenance. I guess maybe I should not have removed the intake lid, but wanted to take a look. Maybe the flappers are hung up.
Old 06-24-2017, 05:02 PM   #4
I think if you search for Vue flapper valve issues within these forums you're likely to find info.
Tags
intake flappers, intake manifold, saturn vue
2003 L300 V6 Upper Manifold Intake Runner issue floridasl22002 L-Series General 3 05-20-2017 05:23 PM
l300 idle races, is this an intake manifold issue? dbinteract L-Series Tech 2 04-19-2014 09:18 PM
Ran into a possible intake manifold issue... NotAHondaDriver Ion Mods 4 11-22-2013 10:11 PM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
95 SL1 intake manifold twstdstrn S-Series Mods 1 06-01-2001 08:13 PM
