Old 09-26-2015, 01:27 PM   #1
bigrig747
bigrig747 is on a distinguished road
Default no spark 98 saturn
I took it to a shop little over a month ago and they told me it was not getting spark but the got it running. Well a week ago started having the same issues so what I have figured out is that if I apply pressure on the top of the icm plug I can get it to run but if I let go of the plug it will stop running. Any ideas on how to keep this car going? Thanks!!
bigrig747 is offline   Reply With Quote
Old 09-26-2015, 04:43 PM   #2
toggenburg
toggenburg's Avatar
Default Re: no spark 98 saturn
Most likely you need to replace the wire set.
How old and what type spark plugs?
Old 09-26-2015, 05:06 PM   #3
Bildo Baggins
Bildo Baggins is a jewel in the roughBildo Baggins is a jewel in the roughBildo Baggins is a jewel in the rough
Have you removed/cleaned ICM? Concur on possible wires but if it quits completely, sounds like connection issue on ICM.
Bill from Extreme Southern North Carolina
'97 Satty SL2
280Kish miles
Bildo Baggins is offline   Reply With Quote
Old 09-26-2015, 09:44 PM   #4
toggenburg
toggenburg's Avatar
^^ Correct. If the metal clip inside the wire boot is expanded, then that's why the connection only works when they hold the wire on the ICM. Replace wires and all should be fine.
Odd that a shop did not replace the wires a month ago.
Tags
no spark
99 Saturn SL1 No spark Spectacularbob S-Series Tech 10 01-13-2019 01:49 PM
i have a 96 saturn sl2 wont get spark plz help possaturn S-Series Tech 1 03-12-2015 10:27 AM
Do you put spark plugs in your Saturn often? AtlanticBeach S-Series Tech 7 08-02-2009 07:56 PM
1999 Saturn SL2 no spark HELP!!!! jsaid S-Series Tech 2 02-04-2008 10:38 PM
96 Saturn - New Spark Plugs + ZAP ZAP ZAP Geodesic17 S-Series Tech 20 02-18-2006 11:52 PM
