Old 12-10-2014, 09:08 AM   #1
numonekobefan
numonekobefan has a spectacular aura aboutnumonekobefan has a spectacular aura about
numonekobefan's Avatar
Post Looking for Engine Harness Wiring Diagram and ICM Connector
Hi guys,
I have a '96 Saturn SL2, and I am having misfiring issues. I have been unable to find a good wiring diagram online. Most of the ones I've found don't include the Ignition Control Module Wiring (ICM). Does anyone have a link to the diagram for the '96 SL2? This particular ICM has 5 pins, and NOT 6 pins as most of the wiring diagrams I've seen online.
The other thing I am looking for is for the actual plastic connector that plugs in to the ICM. Like I said, it is a 5 pin connector. I believe the wires may be bad underneath the plastic sheath/jacket since when I bend that section of the harness the problem only gets worse. I'd like to replace those wires along with the connector as far back as I can to eliminate that issue. Thanks!
numonekobefan is offline   Reply With Quote
Old 12-10-2014, 09:26 AM   #2
Default Re: Looking for Engine Harness Wiring Diagram and ICM Connector
Go to a pick and pull and cut the connector and wire off of any 96 or newer S-Series car. Each pin on your connector is labeled a,b, c etc and all you have to do is keep track of the wire colors when you splice in the new connector and wire. the problem is most likely in the connector but get as much wire as you can. The parts are no longer available OEM. Each splice must be soldered and heat shrink insulated. NO Crimp Connectors as they will fail.
Old 12-10-2014, 09:44 AM   #3
numonekobefan
Sad Re: Looking for Engine Harness Wiring Diagram and ICM Connector
Thanks OldNuc. Yes, I have come to the conclusion that those connectors are no longer available anywhere. I did see that Motec uses the same coil pack plus ICM in their catalog, but I didn't have any luck finding the connector itself. Going to the pick and pull was going to be my last resort since I live in Michigan, and it is winter season now. A trip to the pick and pull this time of year is painful.
Old 12-10-2014, 09:54 AM   #4
SRGW
1997 SL1
Post Re: Looking for Engine Harness Wiring Diagram and ICM Connector
Is this of any help??
1995 SL1 212,963 Well Oiled!!
1997 SL1 44,250 Just A Teenager!!
CHECK YOUR OIL!!
Old 12-10-2014, 10:01 AM   #5
numonekobefan
Thumbs Up Re: Looking for Engine Harness Wiring Diagram and ICM Connector
OMG Yes! Thanks a bunch SRGW! You don't know how long I searched for this on google. I kept seeing stuff for 95 and back, which has different wiring. Thanks again!
Old 01-12-2015, 07:23 PM   #6
boatmoter
boatmoter is on a distinguished road
boatmoter's Avatar
1993 SL2
if you still need the wiring diagram,send me a message,my tech info goes from 82 to 99
boatmoter is offline   Reply With Quote
Tags
engine harness, icm connector, igntion control module, misfire issues, wiring diagram
wiring diagram for harness in trunk keepsongoing S-Series Tech 2 06-03-2011 09:50 PM
Need wiring harness diagram for 2004 2.2L VUE kim_lombard Vue General 1 04-22-2008 08:29 AM
wiring harness diagram smok S-Series Tech 3 12-16-2006 09:04 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 05-01-2005 12:45 AM
Wiring Harness Diagram tristanlee85 Miscellaneous Tech 1 09-06-2004 01:09 PM
