Old 07-11-2014, 04:01 PM   #21
Kellyam
Kellyam is on a distinguished road
2002 SL
Default Re: 2002 SL-2 5spd won't start
I realize for sure that it may be the starter. Just don't want to believe it cuz it's pricey I will look at the battery cables, connections, etc. I will hit the starter with a stick LOL, and I might start a journal describing how long between starts/etc. Definitely needs a tune-up, though from what I've seen on here, doesn't seem like that is the root cause of the issue, though I'm sure it isn't helping.
Kellyam is offline   Reply With Quote
Old 07-11-2014, 04:04 PM   #22
Kellyam
2002 SL
Originally Posted by alordofchaos View Post
sorry, I wasn't clear... what I'm trying to figure out is, did the starter have time to cool off before the car started again? When my starter was dying, it would take 20~40 minutes to cool off, then it would start fine again. Started perfectly every morning when it was cold. Would start fine after really short trip, because it never heated up.
Not sure what you mean by "3 or 4 rotations" - you mean the engine would crank 3 or 4 times but not start?
Sorry, thought I was being smaht by using the term "rotations"- I can't remember what my uncle said, it was something like when you run the codes in a car, and they go away, if they come back in a certain number of... oh wait I think the term is "cycles"??
So I meant, it started up fine 3 times over the course of 6 hours, then wouldn't start.
Old 07-11-2014, 04:11 PM   #23
TXSaturn02
TXSaturn02's Avatar
Originally Posted by Kellyam View Post
Also it makes a quiet almost like a breath exhalation "put-put" sometimes and the engine shimmies, and this has been this way (not consistently of course) since I bought it. It does this that I know of while at a standstill, idling in 1st usually. She's trying to tell me something but I can't figure it out!
I don't think this particular issue is related to the starter - separate issue, if you ask me. The more you wait to address an issue, the more others can come up which make diagnosis tougher.
New owner report of 08/08/19: 234,408 Miles
As of 11/12/20: 78,895 Miles
Old 07-11-2014, 04:19 PM   #24
Kellyam
2002 SL
K I just finished reading over the new or returning saturn owners checklist (which is AWESOME BTW). I'm wondering about the temp gauge (ECTS). My temp gauge always hovers around 1/4, and only reaches almost 1/2 when it's been running for awhile and it's very hot out. Is that normal?
Old 07-11-2014, 11:55 PM   #25
Ebay or dbelectrical.com seems to be the lowest cost starter replacement if you don't mind waiting.
Your '02 has the correct brass coolant sensor so the most likely culprit of a fluctuating temperature gauge needle is most likely a worn out thermostat. Replace it along with new coolant if its due.
Old 07-12-2014, 12:19 AM   #26
J.W.
J.W. is a jewel in the roughJ.W. is a jewel in the roughJ.W. is a jewel in the rough
2001 SL2
With ANY auto electrical problem...FIRST - Clean BOTH battery cables at the battery, and the battery terminals. ALWAYS !
It is cheap, easy, and quick. It will also surprise you much of the time !
JW
J.W. is offline   Reply With Quote
Old 07-12-2014, 02:01 AM   #27
Signmaster
It sounds like maybe you have a misfire of some sort. If your friend has the tools, checking out the spark plugs is one of the primary causes of this, and they are cheap and easy to replace. $8-$10 will often smooth things out, give you more power, and help MPG.
But I have to admit, when I saw you say this...
Also it makes a quiet almost like a breath exhalation "put-put" sometimes .......
... it made me laugh. I'm getting older, smoked for many years, and I still don't make any "put-put" sounds when I exhale. Well except for maybe when I was a little kid, and they went something like this.....
Insanity Test
Old 07-15-2014, 04:51 PM   #28
Kellyam
2002 SL
Oops I meant to write "putt putt" like a sputter.
Anyhoo, I know I shouldn't have, dont' worry I didn't let them touch anything, but I went to VIP and had them run the diag test on the battery. They said my starter was going/gone. Then today my friend says, they can't test the starter without taking it out. Haven't been able to clean the cables yet as I don't have a lift, but I'm wheedling at my friend to get her to have her husband help me, possibly this weekend (I hope). Sunday friend coming to do tune-up. Tonight possibly serp belt replacement. VIP was like, it is all cracked, and I looked, and it was/is.
Didn't drive the car at all on Sunday after having to jump it every time for Thurs/Fri/Sat. Then yesterday at noon, started up fine. Started up 4 times fine yesterday, and twice so far today. I keep vascillating back and forth between it's the starter, or it's a connection issue. I will do the cheapest/free things first. Then worry about a starter. Thanks again for all of your help on here. Don't kick me out for going to VIP, OK?!
Old 07-16-2014, 12:44 PM   #29
correct. probably what VIP did is tested the battery, and since the battery tested OK, guessed it was the starter. It can be expensive when other people guess
I might have missed it, but are we talking about the battery cables? You can reach those (or at least most of it) from the top.
There's a good video on belt replacement. On the Saturn, it's probably a 1/2 hour job for a beginner. Frankly, most of the time will be spent removing the tire and jacking the car up. the actual belt replacement is like 5 minutes. Easiest car I've ever replaced a belt on. If it's not too badly cracked and stretched, should be ok for a while.
Engine hot or cold when it started/failed?
Always a good plan
Saturnfans is not that kind of site
you may want to put a general location in your profile... might be someone nearby who can take a look, loan tools, etc. I pretty much have zero time these days, but willing to let you borrow my jack, stands, etc
Old 07-17-2014, 04:52 PM   #30
Kellyam
2002 SL
K this is what the EXP800 at VIP says about my battery/starter:
"Results
Good Recharge
Voltage: 12.55V
Measured: 541 CCA
Rated: 650 CCA
Temperature: 95F
Battery is Good but Low on Charge. Fully Charge Battery.
Starter Test
Results
Cranking Skipped
Voltage: 0.00V
Time: 0ms
Starter Profile Not Detected.
Starter Test Skipped.
Charging System Test
Results
No Problems
No Load: 14.22V
Loaded: 14.13V
Ripple 57mV
Charging System Output Test Normal"
Did they actually test my starter???
Old 07-17-2014, 05:17 PM   #31
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Sounds like they " skipped " it.
Until you find someone who has basic knowledge of diagnostics and can then report the results back here this will continue to be a guessing game. Or if you have a few extra bucks you can buy a starter at www.dbelectrical.com for $ 50 and have someone install it. This will then eliminate one piece of the puzzle.
97 sl2 a/t 104 K
Old 07-17-2014, 08:03 PM   #32
Starter Test
Results
Cranking Skipped
Voltage: 0.00V
Time: 0ms
Nope. If there is a starter test that can differentiate between a new one from a worn one, I personally would like the pdf, printout, equipment name/model and literature so I can Google it online and participate in becoming more informed about starter troubleshooting otherwise there are no definitive tests that anyone or anything can perform to tell the difference between a new one or old one. Nothing. Experienced people well aware of how starters work and how they wear out will ask car mileage, whether car is driven locally with frequent stops or twice for the daily commute to/from a job, whether or not other people use this car frequently, etc.. There are no statistics to tell anyone how long a starter will last or when they fail. No one. As long as a starter passes new car warranty, its all free after that until it fails. Long term ownership implies long term wear and tear on parts either ignored or forgotten about until problems pop up out of nowhere; batteries, starters, alternators, a/c systems.
As mentioned by another member, power is the first consideration requiring everything before a starter to be in clean, good operating condition; battery, battery cables, their connections on both ends. Since your VIP report appears to show the power system is in good operating condition, the starter remains as the most likely problem. Starters can fail in as little as 70k miles or after 250k miles. Frequent short trip driving wears out a starter due to several starts in a day while long commutes to a job and back home with only two starts shows a starter lasting well beyond mileage when most cars are traded in, leaving someone else with the problem of long term wear and tear items that eventually wear out.
Old 07-18-2014, 09:22 AM   #33
Kellyam
2002 SL
You guys ROCK
Thank you
Old 07-11-2015, 09:46 AM   #34
rodriguezsa
rodriguezsa is on a distinguished road
I am having a similar problem with my 2002 sl2, but I have a new battery, a new alternator, and I replaced the starter about 5 months ago. The car is behaving as if the starter is bad, just a click from the starter when I try to turn it over, but I took it to the auto parts place, where I bought it, to have it tested and they have told me it is good. What do I do next?
rodriguezsa is offline   Reply With Quote
Old 07-11-2015, 09:52 AM   #35
rodriguezsa
Old 07-11-2015, 11:03 AM   #36
Read post #32. If you ensure the battery, battery cables, their connections are clean and in good condition, the starter is faulty. The battery can be tested at most auto stores but you have to examine cables and their connections carefully for severe corrosion, under the heavy insulation to be sure a previous battery didn't leak acid into cable lugs and eat away copper wires. If you are assured both battery cables and their connections (to engine and chassis ground too) and battery are good, replace the starter.
Old 07-11-2015, 12:24 PM   #37
billr
Just a click and no other sound, no engine cranking or faint whir of an electric motor turning? As always, no-crank problems are best tracked down starting at the famous "purple wire"...
Also, I have found that part-store testing of starters is meaningless. Good ones can test "bad", bad ones can test "good"!
Tags
alternator, battery, starter, tune-up
2004 Vue 5spd Won't Start KJMcCoon Vue Tech 11 05-13-2014 09:34 AM
header and intake 2002 vue 5spd? dirtydawg Vue Mods 8 04-06-2014 02:55 PM
1997 Saturn SL 5spd WONT START! KeonTheGreat S-Series General 2 08-25-2013 06:46 PM
02 SC2 5spd won't start cold/strange idle flyjetguy S-Series Tech 4 12-29-2009 10:37 AM
2002 SC2 won't start :-( anderma8 S-Series Tech 7 02-18-2007 10:25 PM
