Old 11-01-2013, 09:54 AM   #1
Texican1
Texican1 is on a distinguished road
Wrench 07 V6 got wet, won't attempt to start
So I'm sure you've seen our drizzles in Texas the last few days. My son pulled out into the street behind his gf in her Lumina that made it trough the water and he started sputtering and tried to get back to the driveway and stalled out. I've seen the pic, water is at about the hub on the driver steer tire which is the lowest point of the road, the rest of the car is shallower.
Somehow he got water in the airbox and then into the intake. He and his friends pulled the intake and throttle off to get the water out and then drained the oil. We put it back together and oiled and filtered it. It doesn't attempt to start. The starter yesterday would make a single click, but not even as much as a dead battery amount of noise. We let it dry over night and now it does nothing.
The battery is good, plus we tried jumping it. The starter fuse is intact. Any ideas on where to start looking for the gremlins?
Texican1 is offline   Reply With Quote
Old 11-01-2013, 10:46 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 07 V6 got wet, won't attempt to start
See attached thumbnail for engine start ... I don't see a start fuse - are you referring to the 30A Ign Fuse?
The 3.5 start relay is one of the small Bosch types and is attached to engine side of under-hood fuse and relay box (UHFRB).
If the battery is powering UHFRB (headlights and other accessories operate) - and start relay does not click with key to START - the transmission safety switch could be bad ... I'd try with gear shift to neutral.
If small relay does click but starter does not run - starter - or solenoid - or both could be water-logged.
Old 11-01-2013, 11:10 AM   #3
satlite440
2001 SL2
pull the pl;ugs out and see if it will crank over.. hopefuly it didn't ingest water and shorten a connecting rod as water does not compress and water ingestion usualy involves a bent rod...good luck..
Old 11-02-2013, 01:49 PM   #4
Texican1
Ok sorry for the delay, long day yesterday. Yes, it still clicks when the key is turned while in neutral. Taking the plugs out won't help when the starter doesn't spin. Got a errand to run then I'm going to pull the starter off and take it to autozone to get checked.
Old 11-02-2013, 03:25 PM   #5
Texican1
As a side note, none of the relays are marked starter.
Old 11-02-2013, 03:58 PM   #6
far2grumpy
far2grumpy's Avatar
I tried to emphasize the 3.5 engine start relay is not marked or in relay box.
It probably doesn't matter now - since you hear relay click when key is turned to start ... but see the thumbnail if you need to locate for later troubleshooting (relay view possible because I rotated air intake snorkel toward radiator).
You've probably done so but I'd pull all plugs before trying the new starter - one or more cylinders can have water and if cylinder's on compression stroke - oh boy.
Old 11-02-2013, 04:48 PM   #7
Texican1
I'm at the point I'm ready to throw wrenches and my neighbors are looking for the cussing. How do you get the starter out? I can't get my hands in there. Battery is out, solenoid 1 nut off and unplugged. Can't reach anything else with all the hoses and wires in the way.
Old 11-02-2013, 05:05 PM   #8
far2grumpy
far2grumpy's Avatar
Not much room ... best I can offer is service manual extract. See post 13 of this thread for starter replace (rules prevent adding again):
http://www.saturnfans.com/forums/sho...d.php?t=151013
I am able to add a thumbnail with starter removal steps (see below).
Old 11-02-2013, 05:09 PM   #9
Texican1
Ok, plugs are out. Since it won't crank, how do I tell if there is water in the cylinders?
Old 11-02-2013, 05:13 PM   #10
Texican1
Thanks for the link, but the problem is getting to it. All the radiator hoses and wiring harnesses are in the way. Can't get a wrench or socket into it.
Old 11-02-2013, 05:40 PM   #11
Texican1
And interestingly enough, the Haynes manual shows the mounting bolts going parallel, not perpendicular
Old 11-02-2013, 06:25 PM   #12
Texican1
So it seems the 2 bolts I took out aren't the right ones, and now one has dropped into the motor and I can't find it.
Just because I'm not certain based on the description from the Haynes manual, the starter is smaller than a 12 oz coke can and to the left and down from the battery, right? Solenoid sitting right on top of it? The manual says there's a rubber boot on the end with a bolt under it which isn't the case.
Old 11-02-2013, 07:12 PM   #13
far2grumpy
far2grumpy's Avatar
You'll need a working starter to spin engine to expel water from cylinders.
I'd use cord or rope to re-position radiator hoses to improve access.
I'd also remove EGR valve to improve access to starter.
I'd also remove the small bracket with engine harness and battery positive cable to improve access.
The starter is to left and below the battery and centered and behind transmission fluid dipstick and my starter is larger than 12 oz coke can and solenoid is mounted on top of starter.
Starter has two bolts (per diagram) which are perpendicular to starter frame.
Old 11-02-2013, 09:16 PM   #14
Texican1
Ok then I'm in the right place. 6 hours later I gave up for the night. My neighbor reconnected the battery and crossed the posts on the starter and it didn't react. We took that harness loose in the front but that's when the Mosquitos decided it was dinner time. Back at it tomorrow.
Old 11-04-2013, 01:38 PM   #15
topcat
topcat will become famous soon enough
topcat's Avatar
If you're still working on this, the next thing to do is put a wrench on the crankshaft bolt and turn the engine over by hand. If it's hydro locked then it's probably will not turn and not a starter issue since even a good one won't compress water. An engine ingesting water into the cylinders will need repairs beyond the scope of most DIY-ers. Best of luck.
topcat is offline   Reply With Quote
Old 10-25-2018, 06:42 PM   #16
everett lynch
everett lynch is on a distinguished road
thanks for the relay location I have not heard the relay click with the key on when this happened,i will check tomorrow and get back to you,thanks.
everett lynch is offline   Reply With Quote
Old 11-01-2018, 09:44 AM   #17
Cavell
i got an 04 v6 last spring with a bad starter. remove battery and tray. pretty simple. than you reach down and get access to starter. seller said starter was flaky and i drove it for several days and had no issues. replaced starter and it seemed to crank the same. so i figure it was a solenoid issue?
Tags
starter, wet, won't start
95 SC1, Wont start, Or even attempt to start. JasonRW S-Series Tech 9 03-22-2009 01:02 PM
95 SC1, Wont start, Or even attempt to start. JasonRW S-Series General 1 01-18-2009 08:13 PM
Last attempt to fix clutch problem MikeNW S-Series Tech 27 05-26-2008 01:44 AM
My first attempt at reducing understeer alleninpa S-Series General 1 08-10-2007 07:45 AM
It was a nice attempt.... TwiztidSanity S-Series General 11 11-24-2005 09:26 AM
