Old 12-03-2009, 12:13 AM   #1
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
Default Carbon behind throttle, intake manifold
I recently cleaned the throttle body on my SC1. It had about 1/16 inch of carbon build-up on the back side of the throttle. There's a similar amount of carbon all in the intake manifold.
I have two questions:
1) What causes the build-up of all that carbon? Could it be accelerated by a bad ECTS / bad thermostat causing the PCM to run super-rich?
2) How does one best clean out the carbon build-up in the intake manifold? Or does this not affect the engine much?
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
aa4lr is offline   Reply With Quote
Old 12-03-2009, 12:30 AM   #2
Default Re: Carbon behind throttle, intake manifold
The carbon crud is from the exhaust recirculation. It is made worse by the increased oil consumption. If you were running rich and cold then that will cause it to stick better.
If you want to clean it you have to remove the manifold and soak it in something like Purple Power till it all comes out. Its not causing any serious problems so you do not have to clean it out.
Old 12-03-2009, 01:25 AM   #3
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
I remove the throttle body and use a ruler with blue shop towels wrapped around it. Works to get at least some of the gooey crud out. I also remove the egr at the same time and blast compressed air through those passages. Once on the 95SLone I got it so clean took a couple days for the idle to balance itself back out after the clean.
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
ttreibel is offline   Reply With Quote
Tags
carbon, intake manifold, throttle body
Cleaning Throttle Body on 1999 SL2, Intake manifold looks to need it more Bjorno S-Series General 3 04-15-2009 07:25 PM
What causes throttle body carbon stlouis1997sl S-Series General 7 06-26-2006 06:03 PM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
Port Matching Intake Manifold to Throttle Body? Wraith Mods and Performance 9 09-25-2003 11:01 PM
Carbon Fiber intake?? MeaNGreeNSL2 Mods and Performance 8 09-05-2002 12:46 AM
