Old 12-16-2008, 01:11 PM   #1
joshusmc80
joshusmc80 is on a distinguished road
joshusmc80's Avatar
Question shifter cable help
I have a 99 sl2 5 speed. On my way home from work a few days ago, I down shifted into 3rd gear to exit I-75 and when I went to upshift again my gear shift was completely free from all resistance(like it was not attached to anything at all). I was stuck in third gear but I managed to get home safely.
I discovered that one of my shifter cables had broken near the transmission. I purchased and installed new cables. However, the shifter seems to be stuck sort of leaning towards the passenger side of the car. I can shift into what I think is 1st gear but it is in the 3rd gears position, but that is it. I installed everything back into the car the way it was but I still cant figure it out. Is there a special way to adjust these cables. The manual says installation is the reverse of removal. Am I missing something?
I have been searching these forums for a few hours but I can't find anyone else with this problem. Any help would be greatly appreciated. Thanks.
joshusmc80 is offline   Reply With Quote
Old 12-16-2008, 01:33 PM   #2
Default Re: shifter cable help
duplicate.......
Old 12-16-2008, 01:35 PM   #3
Are you sure that you have the right cable on the right lever at the transmission?
The lower cable is the left right motion of the lever in the car.
Old 12-16-2008, 02:01 PM   #4
rc1488
rc1488's Avatar
Originally Posted by OldNuc View Post
duplicate.......
Yuppp. I just wrote on the other thread attaching your picture
Old 12-17-2008, 03:13 AM   #5
mrbios
mrbios is a jewel in the roughmrbios is a jewel in the roughmrbios is a jewel in the rough
mrbios's Avatar
1997 SW2
After changing the clutch on my 5 speed I had to replace the clips. I had almost the exact same issue you have. I could only shift in 3rd and 5th.
mrbios is offline   Reply With Quote
Old 12-17-2008, 11:02 AM   #6
I changed from an automatic to a manual tranny. I still don't think to this day I've put the clips on to hold the cables to the tranny. I remember thinking about it once, then checking (don't believe I saw the clips on there), then not being too worried about it. Other then the 3-4" shortened shifter which makes changing gears really really stiff I've had no problems with shifting.
Old 12-19-2008, 04:29 PM   #7
joshusmc80
joshusmc80's Avatar
I found out what the problem was. The bracket that holds the cables in place near the shifter was not on right. Once I tightend it down the way it was supposed to be, it would shift beautifully.
I want to thank everyone that took the time to post a reply to this thread. I'll be sure to return with more questions. Thanks again.
Tags
cables, shifter, shifter cables, tranny troubleshooting
shifter cable help joshusmc80 S-Series Tech 1 12-16-2008 01:58 PM
Shifter cable removal jimyoung28 S-Series Tech 19 06-04-2008 08:21 AM
Shifter Cable chamorro83 S-Series Tech 1 08-04-2006 03:20 PM
SHifter Cable Compatiblity vitamaltz S-Series Tech 0 06-20-2006 03:10 PM
can't get shifter cable off!!! need help penleydr S-Series General 2 03-28-2005 04:19 PM
