Old 11-24-2008, 03:14 PM   #1
dpstang98gt
dpstang98gt is on a distinguished road
Default Are SL2's known to burn oil?
well i got my sl2 back today and decided to check the oil that i changed 1500 miles ago, and it was right in the middle of low and full. The motor has 52k miles on it and runs great with no tick or knocking or any problems, that can be seen or heard. So im wondering why is it in the middle and why did it burn the oil? Is this normal or what? thanks for any help
2000 Saturn SL2-DD, mostly stock
1998 Mustang GT- Twin Turbo kit, weekend/track car
dpstang98gt is offline   Reply With Quote
Old 11-24-2008, 03:27 PM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: Are SL2's known to burn oil?
uh oh run you're gonna get swamped with responses...
Saturnless...
Old 11-24-2008, 04:23 PM   #3
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
I thought by 2000 they had dealt with it, but the DOHCs as a rule burned 1 qt. oil per 3000 miles. Sounds like you're right on schedule.
Check it regularly, add oil when it's low, and don't worry too much more about it.
daver is offline   Reply With Quote
Old 11-24-2008, 04:25 PM   #4
Cortana
Cortana is on a distinguished road
Cortana's Avatar
Yes.
IIRC, they made a modification to the piston or rings to reduce it, but the LL0, LK0, L24 are all fairly prone to burning oil with age, based on how they're treated.
Search the forums for any info regarding reducing this, and why it happens.
Also check your oil regularly.
Cortana is offline   Reply With Quote
Old 11-24-2008, 04:30 PM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
by regularly everytime you fill up your tank... As far as the rule of 1 quart every 3K that is completely inaccurate... some people loose a quart every 750 miles. Its cause by the brilliant piston rings. If you are that low of milage, the car is worth the effort, and I would go ahead and re-ring the pisons before it gets outta control and has too many miles for the work (in your eyes possibly)... But its worth the re-ring at such low mileage that if you can do it, or can do it with our help, go for it.
Saturnless...
Old 11-24-2008, 04:56 PM   #6
hholbein
1997 SW2
I have a 1997 SW2 with similar mileage (69K) and it's burned 1 quart every 3000 miles for quite some time. This is a little more than I'm used to with other cars, but it's quite manageable.
I supposed if my engine decided to convert itself into a two cycle and burned a qt every 750 miles, I'd just swap out the antenna for an IV pole and get a 5W30 drip going...
Old 11-24-2008, 05:25 PM   #7
dpstang98gt
so your saying if i dont fix this problem anytime soon it will get worse?
Old 11-24-2008, 05:32 PM   #8
Infinitrium
Infinitrium is on a distinguished road
1994 SL1
My 96 SL2 seems to go through a quart of oil every 1000 miles or so. I check it every 3 or 4 days.
1996 Saturn SL2 automatic. Dead.
1994 Saturn SL1 automatic. Not dead yet.
Infinitrium is offline   Reply With Quote
Old 11-24-2008, 05:33 PM   #9
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
it seems to stay pretty standard on mine. it may get a little worse over time, but i wouldn't worry unless it plummets suddenly at any point.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
dorisSL is offline   Reply With Quote
Old 11-24-2008, 05:33 PM   #10
Infinitrium
1994 SL1
It may burn a bit more oil as time goes on, but it won't blow up on you or anything like that.
Old 11-24-2008, 05:40 PM   #11
dorisSL
dorisSL's Avatar
1995 SL
won't blow up, unless you fail to fill it and run it dry
Old 11-24-2008, 05:49 PM   #12
OnDaGround
OnDaGround's Avatar
1993 SC2
It is possible, very few people do not burn oil, over very little oil. It's just the wonders of the 1.9... Basically, that is the only down side to these motors, given the fact that you maintain it properly, that minus a few easy fixers... will be all that is necessary. Unless like someone else said, you do not catch the lack of oil in time... then bye bye. Take care of a saturn, and the saturn will take care of you... that's the bottem line. Oh and eh change your ects ...
Saturnless...
Old 11-24-2008, 06:00 PM   #13
dorisSL
dorisSL's Avatar
1995 SL
i'm surprised how long it took anybody to say it.
its two of the first three posts in the how-to library.
easy, cheap, necessary.
Old 11-24-2008, 06:50 PM   #14
SaturnTall
SaturnTall is on a distinguished road
2006 ION-2 Sedan
2006
I just sold a 1991 SL2 and I had concern about oil loss. No leaks, no blue smoke from exhaust. I read a column on small, high revving engines and a mechanic said it was pretty normal. Due to the "working hard" nature of the engine, it uses more oil.
SaturnTall is offline   Reply With Quote
Old 11-24-2008, 07:24 PM   #15
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: Are SL2's known to burn oil?
I would not worry about it. With my DOHC 94 117K miles, Mobil 5W30, I use about 1 qt every 2500 miles. And that is with 3-5K RPMS every day. Even a few red lines every now and then. But always keep up on the oil changes, and keep the oil full and you will not have any problems.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Old 11-24-2008, 07:40 PM   #16
Consider this then. All of the people who have posted here with rebuilt engines in which they have either installed aftermarket pistons with improved oil ring return paths or drilled their own drain holes in the oil ring land are reporting an oil consumption of effectively zero. At least one individual has accumulated 70,000 miles on such a modified engine.
The oil consumption has nothing to do with "working hard" or high specific power output but with the total lack of oil return drains from the oil ring land area. It was a design decision based on several bad assumptions.
Old 11-24-2008, 07:49 PM   #17
dorisSL
dorisSL's Avatar
1995 SL
if i remember (and initially read correctly) it's a "feature" based on the quality or lack thereof of the 5w oils that were available at the time
Old 11-24-2008, 08:48 PM   #18
westwind999
1999 SW1
I think it's probably a good time to give Auto-Rx a try. It's been known to do a decent job of cleaning out the engine, particularly when it's not too far gone. It improved my SW1 quite a lot although it didn't completely stop it.
The Search Function is your friend
Old 11-24-2008, 09:18 PM   #19
Yes, and that "feature" was corrected while the engine only existed on paper. Most of the "5w-30 oil ruined my motor" comments came from people who had engines so far gone that they would die on straight 30 weight or the people who filled up with the 5w-30 and then went on a 600 mile trip at 80+mph with 2 stops for gas in 100+ degree heat. The heat breakdown was a real problem and it was promptly corrected. heat breakdown is actually still an issue with all of the petroleum based oils even today. Not a big issue but it can be a problem.
Old 11-24-2008, 09:21 PM   #20
dpstang98gt
what does this mean??
Why do saturns burn oil? saturncrzy S-Series Tech 104 08-17-2015 02:40 PM
oil consumption/burn bdobraj S-Series General 12 08-20-2009 07:00 AM
Changing oil burn? Admiral Beez S-Series General 2 12-15-2005 03:11 PM
Oil Burn? saturn4 General Saturn Discussion 5 06-21-2001 06:07 PM
How much oil do you burn? MrBigglesworth General Saturn Discussion 26 07-28-2000 06:31 PM
