Old 03-20-2021, 05:51 PM   #1
iamkingdude
iamkingdude is on a distinguished road
Dizzy 2004 Vue Sunroof Leak NOT Drain Plugs
I have a 2004 Vue and have been trying to fix the famous sunroof leak for 1 year now. The front and back drains from the sunroof nipples all drain fine. At this point I have every interior trim piece removed including the rear seat belts so I can clearly see all the hoses and connectors.
WHAT I HAVE DONE:
I perfromed the zip tie, super glue fix to the front drains and blew them out as well.
I removed all hoses and the rubber nipple that mounts to the frame panel for the rears and cleaned them all thoroughly.
Now the leak is now coming from the bottom of both sides of the sunroof pan at a joint about 12 inches from rear drain plug nipples and some even makes its way to the rear hatch.
At this point I have every interior trim piece removed including the rear seat belts so I can clearly see all the hoses.
I am out of ideas short of replacing the entire sunroof which I have no experience in doing!
Thanks in advance!
iamkingdude is offline   Reply With Quote
Old 03-27-2021, 06:13 AM   #2
atikovi
Default Re: 2004 Vue Sunroof Leak NOT Drain Plugs
Have you removed the headliner? Should be easy to spot then.
leak, sunroof, vue
Sunroof drain hose observations 2004 Ion Logan Savage Ion Tech 7 07-19-2015 02:59 PM
**sunroof leak not!!! Drain tubes** Bently S-Series Tech 2 06-24-2015 02:34 PM
Why are there two coolant drain plugs and should I use them? satmark S-Series Tech 4 12-05-2013 08:09 PM
Sunroof Leak - not the drain lines this time DaughtersSC2 S-Series Tech 6 11-10-2013 09:01 PM
Location of sunroof rear drain plugs on 4dr SL2 SL296Guy S-Series General 4 01-21-2005 05:04 PM
