Old 10-09-2020, 03:39 AM   #1
Tb51602
Tb51602 is on a distinguished road
Default Coolant Temp Sensor
How would I determine which of these two would be my coolant temp sensor?? The lower one has a yellow and a black wire to the connector, the higher has just one green wire.
Tb51602 is offline   Reply With Quote
Old 10-09-2020, 09:19 AM   #2
Default Re: Coolant Temp Sensor
The correct answer is "Both". They are both temp sensors.
The 1-wire is for the gauge, the 2-wire is for the PCM and runs everything.
Old 10-09-2020, 09:19 AM   #3
BV22
2002 SC1
The single wire unit is for the temperature gauge on the instrument panel. The 2 wire unit feeds temperature info to the PCM.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 10-09-2020, 01:39 PM   #4
Tb51602
Awesome, Thank you for the help!
Old 10-09-2020, 03:10 PM   #5
454cid
I don't think I have two..... did the Gen3 combine them?
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 10-09-2020, 03:19 PM   #6
The single-wire "dash" sensor is gone from '96 onward.
dohc, ects, sl2 1995
coolant temp sensor russellc S-Series Tech 2 03-29-2013 09:06 AM
Coolant temp sensor phoinex17 S-Series General 13 12-14-2010 12:27 AM
Coolant temp sensor? 3500srw S-Series Tech 8 06-26-2008 11:45 PM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
where is the coolant temp sensor buddyc S-Series Tech 2 08-06-2003 06:18 PM
