Old 05-25-2020, 09:45 PM   #1
roeiboot
roeiboot is on a distinguished road
Dizzy Ignition issue
New here, already need help ;-}
I have a Level 1 2005 iON. I “discovered” a while ago that I could remove the key while the car was running, never again did that because I know it’s not “normal”.
Now today my son (he gets his own car Wednesday ;-} came home and the key is out but the car is running. Looks like the ignition is in ACC. Tried disconnecting battery, engine keeps running, tried stalling it -couldn’t do it. As a last resort I remove “fuse”/relay number 25 and that turns it off
I read here that this is an fairly common issue however most I read is where the key is stuck while in ACC. Not in my case, key comes out but car keeps running.
Any ideas? Luckily I’m on furlough but still ;-}
Thanks in advance.
roeiboot is offline   Reply With Quote
Old 05-26-2020, 03:52 PM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2006 ION-2 Sedan
Default Re: Ignition issue
Remove the small plug / cover in the bottom of thee steering column, inside the hole push the solenoid to the left and rotate the key back to lock.
Note: a bad switch in the floor shifter is the problem.
Old 05-26-2020, 04:00 PM   #3
roeiboot
Thanks!
I’ve been poking around in there but no luck so far, I feel what I think is a circular “thing” that’s spring loaded, is that it? Fact that the items in there are +100° isn’t helping
acc, engine, ignition
Ignition Issue 3Lugs S-Series Tech 1 02-08-2015 10:56 AM
Ignition Issue Alaskasmith S-Series General 4 03-18-2014 07:48 PM
97 SC2 - Ignition Issue mystic54 S-Series Tech 3 01-18-2013 01:36 AM
03 Vue anti theft issue and ignition issue jamil0810 Vue General 4 07-17-2012 02:43 PM
Ignition issue Hoagrod Vue Red Line 11 03-29-2012 09:51 AM
