Old 02-25-2020, 01:28 AM   #1
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 - Battery Harnass Removal Problem + Left headlight Removal Issue
Hey everyone. As you might have seen I have been working on getting my car running on a different thread.
In the meantime I need to remove the battery to get it 100% charged up for proper testing and rule outs.
Unfortunately the screw/bolt is under the battery making it impossible to remove from an up and down position.
It seems the only way to remove it (and I already tried from under the car) ... absolutely nothing.
The left headlight (I was able to remove the far right 2 light bulbs and secured them away) however the one on the far left hand side... I cannot figure out how to get the bulb to unlock.
I looked at YouTube and found an example of a 2003 L300 and the owner removed the front panel / "grill" ; which I do not have... it's much different.
Which revealed unlocking tabs on each side of the headlight pack.
Does anyone know how to do this on the 2001 Saturn L300 so that I can put a wrench through where the headlights are sitting and remove my battery so I can get it charged?
Thank you in advance!
Brandon Kastning
BrandonKastning is online now   Reply With Quote
Old 02-25-2020, 04:47 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: 2001 Saturn L300 - Battery Harnass Removal Problem + Left headlight Removal Issue
Found these instructions, hope it helps.
https://www.justanswer.com/saturn/53...urn-l-300.html
Old 02-25-2020, 05:02 AM   #3
imaddicted2u
2008 AURA XE
Here is a video fro Car Kiosk:
https://www.carcarekiosk.com/video/2...eplace_battery
Old 02-25-2020, 09:09 AM   #4
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
I had just changed our lights and you don't need to remove the grill or anything else. On-line shows a lever, but that was not there in our LS2. As I remember there are screws that allow the entire light module to slide and release from the car. Then you are able to replace bulbs easily.
I also sanded the plastic with 80 grit, then 220 grit and 600 grit and then I painted the lens with clear and they looked great. However, it was cold in the garage when I painted the clear and it cracked making it look like broken glass by morning.
Old 02-25-2020, 09:33 AM   #5
BrandonKastning
Imaddicted2u.
Thank you. I seen the video and it was for a 2003 which is different it seems.
Old 02-25-2020, 02:50 PM   #6
Snapshots of the front end with the hood up to show upper cross member, headlights and battery?
The battery tray uses one hold down bolt on the bottom front of the battery, accessible only from the top. A long extension. socket and ratchet should easily fit between battery and upper cross member.
VCX NANO
Old 02-25-2020, 03:29 PM   #7
floridasl22002
Haynes Manual states for battery removal....
1) Disconnect the connections
2) - Remove protective cover (if fitted)
3) - Remove the Fan Control Module. (In the Haynes manual there is an illustration, but the narrative is simple to follow " To disengage the fan control module from its mounting bracket, simply slide it up and off the bracket). This is a small black box in front of the battery and butting up against the cross member. It's located just by the hood stay bracket.
4) - Remove the hold down nuts and the hold down bracket. This hold down bracket appears to be underneath the fan control module. BUT check BOTH sides of the battery for hold down brackets.
5) - Lift out battery
There should be NO need to remove headlight assemblies, going under the wheel arch, etc, etc. It is a SIMPLE job to do.
Old 02-25-2020, 05:10 PM   #8
BrandonKastning
Thumbs Up Re: 2001 Saturn L300 - Battery Harnass Removal Problem + Left headlight Removal Issue
floridasl22002,
Perfect instructions -- I was able to get the job done!
Gallery #1 - 02/25/2020 -- Removing Starter Battery
Thank you again! Haynes won this one!
Best Regards,
Brandon Kastning
Old 02-25-2020, 05:11 PM   #9
BrandonKastning
Gallery #2 - 02/25/2020 -- Removing Starter Battery
Best Regards,
Brandon Kastning
Old 02-25-2020, 05:12 PM   #10
BrandonKastning
Gallery #3 - 02/25/2020 -- Removing Starter Battery
Best Regards,
Brandon Kastning
Old 02-25-2020, 05:13 PM   #11
BrandonKastning
Gallery #4 - 02/25/2020 -- Removing Starter Battery
Best Regards,
Brandon Kastning
Old 02-25-2020, 06:11 PM   #12
floridasl22002
The metal battery tray that you showed in one of your pics is normally painted black but usually ends up looking like yours with rust on it. When I did the transmission job on my son's 2003 L300, I had to remove the battery and the tray and a few more things as well. While the battery tray was visible and out, I cleaned it up and repainted it. You might want to do the same with yours while it's accessible.
Old 02-26-2020, 12:15 AM   #13
BrandonKastning
floridasl22002,
That's very awesome of you to do work on your son's L300. Very good Father. Thank you for the tip. Do you think it's best to get it cleaned up using WD-40? Possibly some PB Buster?
Do I need to invest in sand paper?
Best Regards,
Brandon Kastning
Old 02-26-2020, 03:34 AM   #14
imaddicted2u
2008 AURA XE
Originally Posted by BrandonKastning View Post
floridasl22002,
Best Regards,
Brandon Kastning
You just need to scrape off whatever loose material there is on the battery tray. Then wire brush the rest, wipe off any dust with a rag and paint it with a couple of coats of black rust paint. You don't need to make the metal shiny. There are additives in the rust paint that react with the rust.
This is a good product:
https://www.homedepot.com/p/Rust-Ole...8658/202623091
Old 02-26-2020, 02:06 PM   #15
BrandonKastning
imaddicted2u,
Thank you for this! Helpful information. It's a shame I just got rid of some black paint. Oh well. I will attempt the wire brush at some point!
2001 l300, battery removal, l300 battery, saturn l300, saturn l300 headlights
2nd Gen Headlight Removal... Goggles Pisano S-Series General 2 07-17-2018 12:40 AM
2001 Saturn L300 V6 3.0 P1637 Alternator Left Terminal Circuit deanmerc L-Series Tech 2 10-08-2016 08:58 AM
2001 saturn instrument cluster removal saturnsctwo S-Series Tech 7 08-26-2015 05:29 PM
Saturn SC1 2002 RH Headlight Assembly Repair/Removal travisj027 S-Series Tech 4 07-04-2013 09:47 PM
2001-2002 SC2 headlight assembly removal greencoupe02 S-Series General 1 08-11-2006 09:59 AM
