Old 08-27-2012, 07:43 PM   #1
acemueller
acemueller is on a distinguished road
1998 SL
1992 SL2
Default Could I have messed up the steering - 99 SL1
I've looked for an answer and haven't found one - sorry if this is redundant...
I'm replacing front bearings so taking the knuckle/hub assemblies off. Took off drivers side 1st. Then working on passenger side, with wheel and breaks off, the next step according to some excellent directions on the forum (from twin_cam maybe?) is to remove the nut on the tie rod. I put the socket on it and pulled (correct direction). Before it began to loosen - and without much tension in fact - the entire tie rod came toward me a few inches. I don't know if it reached a hard stop - but it may have - because I repositioned to use my feet to keep it from moving while working the ratchet. Came right off as it should.
So the question, could I have harmed anything? I am guessing not - guessing that I simply simulated steering, presumably even turning the steering wheel? - that the end of the tie rod on the other side moved inwards as the end on this side moved out. Plausible? If not, should I be checking anything before reassembling - I don't want the tires pointing in different directions.
I suppose I'd find out when I put it back together, but if I need to reset anything 1st, that may be better done now and thus the question.
Thanks for any thoughts!
acemueller is offline   Reply With Quote
Old 08-27-2012, 08:06 PM   #2
almoore
almoore is on a distinguished road
1994 SC2
Default Re: Could I have messed up the steering - 99 SL1
richpin has a good video on replacing outer tie rod ends.
"No good deed goes unpunished"
almoore is offline   Reply With Quote
front bearings, steering, tie rod
Who all think this is messed up? clean93 L-Series Tech 7 06-24-2011 07:34 PM
Power steering pump question (new mechanic messed something up) katefan0 S-Series Tech 10 08-26-2008 06:01 PM
She messed up my car. ewalani General Saturn Discussion 11 11-08-2005 03:13 PM
How bad is it messed up? Please help s-seriesguy S-Series Tech 6 09-22-2004 11:44 PM
messed up SL2 xpence S-Series Tech 2 05-08-2002 03:39 PM
