Old 10-08-2008, 10:48 AM   #1
scottyboost
scottyboost is on a distinguished road
Default Suggestions with vibration
I know, I know. Another vibration thread...
1998 SL2, auto, 170k miles.
I've had the car since May, and here's what I've done so far related (aside from standard preventative maintenance):
Changed plugs.
Changed all 4 mounts.
Previous owner replaced wires and coil packs in January.
Ran some injector cleaner with the gas.
What I have is a vibration at idle that bugs me. It's warm idle, in gear. I can see the headlights bounce on the car in front of me, and sometimes the door panel makes some chatter and something from the front end chatters (like plastic cover parts bumping). Otherwise, the car is smooth as silk, and the vibration smooths out if I shift to neutral. The only other notable thing is it misses just a little at idle in park without AC on, and it of course burns oil at a rate of 1 qt per 2000 miles - but neither really bother me.
Ideas? Tks, Scott
98 SL2 207k, still getting 28mpg city
86 Buick T-type 228k, extreme tire shredder
scottyboost is offline   Reply With Quote
Old 10-08-2008, 12:08 PM   #2
Default Re: Suggestions with vibration
Run a compression test. If you have a low cylinder you will have a rough idle.
Old 10-08-2008, 12:48 PM   #3
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
what speed is idling at(rpms)?
Does it have the brass ECTS?
Did you use platinum plugs?(you should not)
Test the resistance of each plug wire, or just replace them.
Good Luck!
Rick
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
rickystarshine is offline   Reply With Quote
Old 10-08-2008, 01:29 PM   #4
Growser
Growser is on a distinguished road
Growser's Avatar
2000 SL1
Have your checked your motor/transmission mounts?
Check out these videos: http://www.youtube.com/watch?v=WGIAt3nzs9Y and http://www.youtube.com/watch?v=zaugUfILmGE
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Growser is offline   Reply With Quote
Old 10-08-2008, 08:11 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
he already said in the first post that he changed all 4 mounts.
SaturnSeries.net owner
Old 10-09-2008, 12:21 PM   #6
Amp67
Amp67 is on a distinguished road
Amp67's Avatar
Did you check for intake manifold gasket leaking (especially near cyl. 1)? Spray brake cleaner in that vicinity at idle. If you see, the idle speed change, you probably have a leak at the gasket.
Amp67 is offline   Reply With Quote
Old 10-09-2008, 01:04 PM   #7
scottyboost
Good Luck!
Rick
Brass - Yes
Platinum plugs - no.
Thanks for the replies.
I'll check wires and intake gasket.
Old 10-09-2008, 01:12 PM   #8
OnDaGround
OnDaGround has a spectacular aura aboutOnDaGround has a spectacular aura about
OnDaGround's Avatar
1993 SC2
Good Luck!
Rick
I have tripple platinum tip plugs... please explain. I have always had them, and still do, never any issues from the LLo
Saturnless...
OnDaGround is offline   Reply With Quote
Old 10-09-2008, 03:28 PM   #9
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Platinum plugs are no good because of the waste spark ignition system used by the s-series. There have been members who's car would not start bc of these plugs. Switched to NGK and the car started no problem. Look for posts by Fdryer for a detailed explanation of the waste spark system.
OP: During idle, open the hood and watch your headlight rattle. Thats the noise your hearing. I used some hot glue to hold a piece of cardboard in place so the headlights would stop rattling. Worked well with no issues
Also, its highly unlikely you have a leaky gasket. That is more for SOHC third generation s-series.
Another thing to check is the EGR. A dirty EGR can cause a rough idle. Clean it using pictures of Wolfman as a guide.
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
rc1488 is offline   Reply With Quote
Old 10-09-2008, 05:18 PM   #10
papayamon2
papayamon2 has a spectacular aura aboutpapayamon2 has a spectacular aura aboutpapayamon2 has a spectacular aura about
2006 VUE 2.2L
You can clean your EGR with pictures of Wolfman??!!!
(Sorry, couldn't resist!)
papayamon2 is offline   Reply With Quote
Old 10-09-2008, 06:24 PM   #11
Crasoum
Crasoum will become famous soon enough
1993 SL2
Just use them like a pipe-cleaner.
1
Crasoum is offline   Reply With Quote
Old 10-10-2008, 12:39 AM   #12
stanleyr
stanleyr is on a distinguished road
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Although RC1488 wrote it's highly unlikely, I agree with Amp67. Check your intake manifold gasket.
The symptoms you described are exactly what I observed with my 92 SL2. Vibrated at idle, (scan showed MAP and spark advance unstable), but smooth as soon as acceleration was applied. So if it is as you wrote - the engine is immediatly smooth upon acceleration - then continue to drive to your local auto parts store and p/u some carb cleaner in the spray can with the red tube to direct it over the intake manifold gasket area. Yes mine had broken and shrunk at number 1. It had covered about 1/2 of the intake port at number 1.
You can wait for the engine to cool down before restarting it and spraying it. Just a quick burst carefully aimed and the idle should really drop if there's a leak. It's by far the easiest, quickest, and one of the least costly diagnostics you can do before you go to all that trouble with plugs, wires and EGR.
Good luck to you!
stanleyr is offline   Reply With Quote
Old 10-10-2008, 02:48 AM   #13
rc1488
rc1488's Avatar
Yeaaa yeaaaaaa :P
True true! A bad intake manifold gasket has crossed generation along with crossing models (sohc - dohc). Though rare its a possibility.
And the EGR is 2 13mm bolts. Quite easy I daresay
Help and suggestions please crater General Saturn Discussion 1 08-23-2008 06:21 PM
Some suggestions bobbyrae Community Center 0 11-03-2006 07:43 AM
I need some suggestions KrgION03 Ion General 37 01-26-2005 05:48 PM
Any suggestions? ---BCB:) Mods and Performance 1 04-04-2002 04:20 PM
Some Suggestions LoveMySL1s Suggestion Box 1 02-03-2001 07:38 AM
