Old 05-12-2022, 07:00 PM   #1
celticwarlock
celticwarlock has a spectacular aura aboutcelticwarlock has a spectacular aura aboutcelticwarlock has a spectacular aura about
Default Seeking a transmission recommendation.
Greetings.
I have a 2001 SC2 that will need a clutch eventually. While the transmission is out, I'd like to have the differential modified or replaced to avoid having it self-destruct somewhere down the road.
The transmission has no shifting issues or problems of any kind. It has nearly 300,000 miles on it, though, so I'd like to address this one failure point at the very least. Although I could probably deal with it on my own, I will not be doing this myself, as I have other projects that need my immediate attention.
Can anyone recommend a competent shop in eastern PA or anywhere in NJ who can install a limited slip, upgrade the pin, otherwise address the inherent differential issue?
celticwarlock is offline   Reply With Quote
Old 05-12-2022, 08:40 PM   #2
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Default Re: Seeking a transmission recommendation.
I'm on Long Island. I never did any Trans work on my saturns.
A guy in my area once offered to do a trans rebuild on my TAAT.
I could maybe contact him (I'm in Bay Shore; Islip area, 1 hr offpeak
driving from NYC). tbhpmciAThotmailDOTcom
Old 05-12-2022, 10:56 PM   #3
Cheaper to just not spin the tires on pavement than rebuild the transmission
If you want to rebuild anything, upgrade/rebuild the shift cables to use heim joints (McMaster 6072K31 on trans end and 6072K154 on the shifter),
I know a few members have documented rebuilding them on here, Waiex191 is the only one I'm thinking of right now. '99 SL2 and a '98 SC2, not sure where in the threads the transmission rebuild comes up but I believe its in one of those 2.
Old 05-12-2022, 11:25 PM   #4
Waiex191
Waiex191's Avatar
Post 174 and on:
http://www.saturnfans.com/forums/sho...=230898&page=9
Not sure how common the failure is. Ours was fine at 204K. Probably not worth it unless you are a nut. You don't have to remove the transmission to change the clutch.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-13-2022, 11:27 AM   #5
celticwarlock
I have long known about this, and I've been careful to avoid spinning the tires. I don't drive it hard, but I'd like to be able to get into it now and then without having to worry. This car is semi-retired and garage kept more often than not. I'd like to get it painted and upgrade a few things over time, and this seemed like a sensible modification to make.
At the very least, I'd like to put a new upgraded pin in there. I saw several threads on this subject, but I've yet to see a part number for the beefier pin. Does anyone have one?
Also, I suppose I can just move the transmission back far enough into the wheel well to gain access to the clutch? Will there be enough room to remove the flywheel as well?
Old 05-13-2022, 02:21 PM   #6
Waiex191
Waiex191's Avatar
Here you go:
https://sites.google.com/site/hunt4s...n/transmission
You can search for user hunt4steve but I think the pictures on Saturnfans are gone - but the link above works.
Originally Posted by Hunt4Steve
I choose to upgrade the Roll-Pin with a McMaster-Carr Coiled Roll-Pin; part number: 95755A331
This particular part number is an "Extra Strength - Steel" Coiled Roll-Pin. If you live in cold climates, it has been suggested that you not select the "Type 420 Stainless Steel", due to the very hard metal possibly becoming brittle in the cold weather. Thus, I went with the "Steel", which is pretty darn hard, and will server my commuter purposes just fine.
Yep
Bryan Cotton
Old 05-14-2022, 02:00 AM   #7
celticwarlock
Excellent!
Old 05-14-2022, 09:31 AM   #8
ultravioletnk
ultravioletnk will become famous soon enough
ultravioletnk's Avatar
2000 SC2
for my cars i just bought a pack of 25 replacement roll pins off mcmaster-carr, part no. 91612A241, as per the late oldnuc's advice. the problem with the oem pins is that they're just the "c" shaped spring pins and are made of excessively brittle metal. i like to spin the tires quite a lot and have had no issues with the replacement pins... unfortunately i did throw a diff pin on the transmission that was in phoebe, which i hadn't yet swapped the pin on. i think there is merit to the suggestions of enlarging the hole and putting a larger pin in, but i also don't think it's necessary. the pin fails due to being brittle and breaking into multiple pieces, which can't happen with the coiled spring pins.
as for replacing it, once you take the transmission apart enough to get to the diff, it's dead simple. drive the old one out, marvel that it was still holding while in multiple pieces (every single one i've replaced was) and then drive the new one in.
rings-1996 sl2 ~215k mi
phoebe-1995 sl1 ~250k mi
janus-2000 sohc2 ~190k mi
tethys-1994 sw2 ~302k mi
rip mimas-wrecked 1996 sw1-trailer
pandora-1999 sc2
dione-1998 sw2
penny [iapetus]-1997 sw2
ultravioletnk is offline   Reply With Quote
Old 05-14-2022, 09:52 AM   #9
celticwarlock
It is good to hear that this is, essentially, a permanent solution. When the time comes, this is definitely the route I'll be taking, unless I acquire a limited slip unit in the interim.
I had no idea OldNuc passed away. It seems he's passed into legend. His posts will be sought out and quoted for a great many years to come, so long as people drive Saturns.
Old 05-14-2022, 10:02 AM   #10
ultravioletnk
2000 SC2
it is truly a shame, but well, i suppose his username wasn't youngnuc. his advice truly is legend on this forum.
pandora-1999 sc2
dione-1998 sw2
Old 05-14-2022, 11:47 AM   #11
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
I will warn that the upgraded pin is not a definite solution, and the same goes for welding the diff pin.
I have blown a trans with a beefed up pin, it lasted maybe a few months of abuse on the turbo car, and I know of a person that has done the same with a trans with a welded pin.
The best solution is to spend the extra coin on a limited slip diff. Ever since I got mine it has been no worries and I never have to think about blowing the trans.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 494,500
1995 Sl2 5spd: Retired Daily, Not Stock: 196,000
1995 SW2 4spd: Daily, Stock: 104,000
Old 05-14-2022, 01:38 PM   #12
Waiex191
Waiex191's Avatar
What I like about the larger pin in the Hunt4Steve procedure is that it is snug both in the differential housing and in the shaft for the spider gears. Stock, I think it was loose in one or the other, so it can whack back and forth a little bit. With the pin I put in, there is no whacking as it is a nice snug fit on both parts. I actually bought Hunt4Steve's leftover pins and his special drill bit, which I used for the shaft. The special drill bit was too short for the housing but that was soft cast iron so I just used a regular long drill and it drilled nicely.
When I replace the gearbox in my '98 I'll do the diff pin mod.
Bryan Cotton
Old 05-15-2022, 06:29 PM   #13
cgg17
cgg17's Avatar
1995 SW2
This is not necessarily true, it depends on the hardness of the pin. Generally, the harder the metal, the more brittle it is. Nothing to do with whether or not it is a coil format.
Seeking advice spitoon Astra General 9 09-24-2019 08:27 PM
transmission top gasket part number and torque wrench recommendation wrparks S-Series Tech 10 12-20-2012 09:56 AM
Desperately Seeking Help johnicelavon S-Series General 5 04-28-2006 10:08 PM
Desperately Seeking Help johnicelavon S-Series Tech 8 04-28-2006 09:52 AM
V6 Engine Seeking davbow L-Series General 3 10-27-2003 02:33 PM
