Old 10-11-2010, 04:44 PM   #1
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
1996 SC2
Default Valve seals on DOHC
Has anyone tried one of the methods of replacing the valve seals on the DOHC without removing the chain cover? I've seen pictures of attempts at suspending the sprockets with 1x4's, etc to hold them in place. I'd be interesting in hearing first hand accounts of these attempts.
-Robert
Old 10-11-2010, 04:56 PM   #2
RobertGary1
1996 SC2
Default Re: Valve seals on DOHC
Hmm, I wonder if this would be useful...
http://www.thetoolwarehouse.net/p-3097-lisle-36880.aspx
Here is a video of it in action, although its hard to tell if there is enough clearance in front of the sprocket to try this in a Saturn with the cover on...
http://www.youtube.com/watch?v=eyMeUsBZcoQ
-Robert
Old 10-11-2010, 05:09 PM   #3
Redhotftw!
Redhotftw! will become famous soon enough
the people that build those little rigs to hold the sprockets do that to swap cams.
the FSM has the head off of the car to replace the valve seals.
1998 "Red Hot" Sc2
Redhotftw! is offline   Reply With Quote
Old 10-11-2010, 05:38 PM   #4
RobertGary1
1996 SC2
I understand that this is not the typical use of the tool. My question is if this would work; not if this is the typical use.
Old 10-11-2010, 05:43 PM   #5
Rob,
That tool will do nothing for you. You need the valve keeper removal tool and a seal remover. The seal remover is about $20.00 and the keeper tool is $50.00. You have to support the sprockets in position, rotation is not an issue.
Old 10-11-2010, 06:07 PM   #6
RobertGary1
1996 SC2
Rob,
So, to your knowledge is there any tool available that will suspend the sprockets for this job?
-Robert
Old 10-11-2010, 06:34 PM   #7
Yes. There is a genuine Saturn tool for the job. And, better yet, if you use advanced search in S-Series and search for "valve seals" there is a thread with pictures of how to build your own tool. If you happen to have solid sprockets it will be a bit of a PITA but it can be done. You do the 2 pistons at TDC and then reattach cams, rotate 1/2 turn and clamp and remove cams and replace the other 2 cylinders worth of seals. You will also have to punch the guts out of a spark plug so you can hold the valves up. You also have to clamp the crank as the air pressure can roll the engine.
Lisle makes a tool to remove and replace the keepers. Lisle 36050 Valve Keeper Remover and Installer Kit.
Old 10-11-2010, 11:26 PM   #8
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
If this is a job to control oil consumption I would also think about the oil rings since they typically get frozen from the lack of drainback holes. Ask me how I know this....
97 SW2 5-Sp 372k
Greg1 is offline   Reply With Quote
Old 10-11-2010, 11:43 PM   #9
It is orders of magnitude easier to change out the valve seals as compared to the rings. The rings will fail if the cylinders are not round, no taper, and within tolerance. When you think rings just go ahead and figure it will be a rebuild.
Old 10-12-2010, 10:27 AM   #10
RobertGary1
1996 SC2
I may well get there. I'm burning at a crazy rate now. About a quart every 400 miles. I don't see smoke at startup and I've not noticed oil on the piston heads looking down the spark hole in the morning. But I'm going to give it a try. I'm not leaking anything because my beautiful garage floor is dry.
However, if I do get there I"m very much considering to it "wrong" and just do a ring job on it. I've only got 155K miles on it and compressions are strong and the engine is very strong (I just drove up the Sierras a couple weeks ago and had lots of power climbing at freeway speeds). Just to make it less proper; I'm also considering doing it in the car simply because I've got too many projects on my plate to make it a long project. I might see if I can get someone to drill the pistons but I've considered just buying new pistons and assuming they will have the proper hole already in them. Anyway, not there yet but I'm betting that's where I'll end up.
-Robert
Old 10-12-2010, 11:42 AM   #11
Low Saturn
Low Saturn's Avatar
2007 AURA XR
-Robert
Here's the orricial Saturn tool:
Here's what we made:
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-12-2010, 11:59 AM   #12
RobertGary1
1996 SC2
Interesting. Looking at the GM repair pictures, your tool looks more like the GM tool than the original.
Old 06-27-2022, 03:20 PM   #13
DEugene
DEugene will become famous soon enoughDEugene will become famous soon enough
I know it's been some time....but where and what is that Official Saturn Cam Holder and where do I find it?
DEugene is offline   Reply With Quote
Old 06-27-2022, 04:36 PM   #14
I will likely have to be DIY fabrication.
Old 06-27-2022, 10:07 PM   #15
cgg17
cgg17's Avatar
1995 SW2
I have had success with using a 2x4 and some C-Clamps.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 494,500
1995 Sl2 5spd: Retired Daily, Not Stock: 196,000
1995 SW2 4spd: Daily, Stock: 104,000
Bad Valve Seals? almoore S-Series Tech 7 05-05-2010 04:24 PM
Valve seals MacG S-Series Tech 3 08-09-2009 04:19 PM
Valve Seals manykids S-Series Tech 38 05-14-2005 01:57 PM
valve seals Applefool Miscellaneous Tech 12 05-15-2003 10:17 PM
valve Stem Seals 91SL2 S-Series Tech 5 11-15-2000 08:58 PM
